STILLEN Rear Window/Trunk Spoilers
Old May 29, 2009 | 10:28 AM
ANNINO's Avatar
They are being delivered on Tuesday (June 2nd). Anyone do the install themselves? Is it as simple as applying the double sided tape and making sure they're straight? I am going to shop around for a body shop to paint them but hope I can get away with installing them myself (with help). My technical skill is probably rated around 8ish.
Are there any techniques or surface treatments that should be used to make sure there is maximum adhesion? Or am I better off coughing up the dough to have the shop do it? I dont want these things flying off on the highway...
Old May 29, 2009 | 02:53 PM
MaxDOuT's Avatar
I ordered my roof spoiler yesterday as well. When I had my clk55 i had a roof spoiler put on and the way they did it was obviously clean the window with windex and newspaper. then they applied some kind of black glue type adhesive out of a tube, then they put the spoiler on as well as having the self tape adhesive it comes with. Pushed it down very well and make sure you do this early in the day so that it gets as much heat as possible, don't do it in the rainy weather or at nite. Make sure you put tape on both sides after you install the wing to hold it down as tight as possible. Also make sure you use the type that won't damage your paint so that after the 24hrs pass you can take it off without getting any tape residue on your upper panels. Hope I don't sound confusing but I also don't know much about this.
Old May 30, 2009 | 11:59 AM
ANNINO's Avatar
Ah yes, the black goop. I remember that stuff from when I put side skirts on my car in high school. I may see how much the body shop wants to charge me to do it... I would think it would be like an hour extra of labor.. we'll see when they get here i guess..
Old May 30, 2009 | 03:00 PM
JSMax's Avatar
Sold
1) clean the window with an alcohol swipe.
2) use the 3m double sided tape that has the red backing. It has much stronger adhesion.
3) apply spoiler to the car.
4) open been and admire a job well done.
done and you have saved some money.
Old May 31, 2009 | 07:53 AM
ANNINO's Avatar
What about the trunk spoiler? Is it necessary to use any other adhesive or is the 3M tape sufficient? Do I need to use the "adhesion accelerator" STILLEN lists as an option to the install in the instructions? Should I lightly sand the area where the tape is to adhere? I am really hoping this is as straightforward as you say it is... prep the area well and slap it on..
Old May 31, 2009 | 08:16 AM
96blackmaxSE's Avatar
boost me.....
Honestly, I think you are over-thinking this. Its not that serious of an install, You will probably be okay with the 3M.
Old May 31, 2009 | 01:11 PM
ANNINO's Avatar
So be it.
Old May 31, 2009 | 04:03 PM
bk2k3max's Avatar
Originally Posted by ANNINO
So be it.
Ok, I feel that it is time that I chime in on this since I have both a Rear Decklid Spoiler for the Trunk and a Rear Roof Spoiler.
For the Trunk/Decklid Spoiler I would definitely tell you that it should be drilled to be installed if it has the Rear Mounted Stoplight embedded into the Spoiler.
For the Rear Roof Spoiler all it takes is the 3M Tape that is installed on it already for you to just set in. If you want to have it hold even stronger then either use Permatex Clear RTV Silicone or Gorilla Glue to help hold it more securely in place.
[IMG][/IMG]
Old May 31, 2009 | 06:16 PM
timberlv22's Avatar
Does the roof spoiler from Stillen come in black? Reason being I have a tuscan sun colored max, just wondering if it does come in black whether to leave it black or just get it painted.
Old May 31, 2009 | 07:24 PM
ANNINO's Avatar
[IMG][/IMG]
The trunk spoiler is just urethane, no rear light. That being said, the 3m tape should be sufficient I think, maybe with the RTV sealant you recommended. I don't really like the idea of gorilla glue on my paint... that stuff is nasty from what i've seen.
Old May 31, 2009 | 07:27 PM
ANNINO's Avatar
I would highly suggest getting it painted. I think it should come looking pretty unfinished... nothing you would want to mount on your car as-is.
Old May 31, 2009 | 08:08 PM
KillaKam's Avatar
I believe it comes black its just the urethane pretty much so its no glass no nothing.
Old Jun 1, 2009 | 05:53 PM
bk2k3max's Avatar
Yeah, it comes in black but it is simply the basic urethane material with no primer or coating of any kind.
I got mine painted with the exact paint for our car for $80.00, I think it is worth it and it looks totally stock to the car, in fact i took the car to the dealer and one of the Salesman didn't even realize that it wasn't a stock part of the car.
I love the looks I get in my car, ppl are always oogling.
Old Jun 2, 2009 | 04:25 AM
ANNINO's Avatar
Nice, 80 bucks ain't bad.. If I can get out of there with both painted under $200 I'll be happy. I can't wait to get these things on... they are my last exterior mod until I get 20's in the spring.
Old Jun 5, 2009 | 10:42 AM
airwolf09's Avatar
let post some pictures when you guys get it done. I want to see how it looks before I put on my
Old Jun 5, 2009 | 11:40 AM
KillaKam's Avatar
This guy has the Stillen Roof Wing installed on his car. I can't take the pic's off of his car domain cause they would be to small so here is the link to it. http://www.cardomain.com/ride/3180937
Old Jun 5, 2009 | 12:23 PM
ANNINO's Avatar
I will definitly post pics when they are on. I ended up at a local Chevy dealer body shop to get them painted. They were incredibly nice, and blew EVERY other place out of the water... $150 to get both pieces painted, and a FREE install. I am pumped. They should be put on Monday, so I will post the pics when all is said and done.
Old Jun 5, 2009 | 12:47 PM
KillaKam's Avatar
Wow that is a awesome deal to get those done... What chevy dealership did you go to? When i order mine i'll probably go to them as well.
Old Jun 5, 2009 | 02:04 PM
ANNINO's Avatar
Don Mallon Chevy/Cadillac on Rt. 32 in Norwich, just North of Mohegan Sun.
Old Jun 6, 2009 | 06:05 AM
VTenge's Avatar
He also has the partially opened sunroof wing installed.
Old Jun 6, 2009 | 10:52 AM
ANNINO's Avatar
He also has a crapload of cleaning supplies. They really help give an idea of the size of the car in this pic.
Old Jun 7, 2009 | 10:22 AM
KillaKam's Avatar
Nice thanx for the info
Old Jun 11, 2009 | 01:26 PM
ANNINO's Avatar
Here's some pics of my spoilers.... Finally got them on today. Apparently the urethane kept sweating some sort of solvent in the oven... They had to repaint them 3 times before the problem finally stopped. They prepped the pieces just as STILLEN advises, but apparently there is more to it... Anyway, here they are. They look great, the butt of the max looks so much better with the spoiler(s).
Old Jun 11, 2009 | 02:45 PM
Mreim769's Avatar
Looks great man! And thanks for not putting on a "carbon fiber" spoiler . Kids these days......
Old Jun 11, 2009 | 03:15 PM
bk2k3max's Avatar
looks good Bro, you finally caught up with me, LOL!
What's those things on the bottom rear sides of your car?
Are those Mudflaps? If so, I'm not feeling those too much they bulk out from the car and look out of place..
Old Jun 11, 2009 | 03:21 PM
ANNINO's Avatar
Haha thanks. Ya know, those 3 foot tall aluminum/CF spoilers were REALLL tempting but I decided to keep it classy.
Old Jun 11, 2009 | 03:29 PM
ANNINO's Avatar
Thanks, I like the rear-end a lot better now, it was too rounded before.
Yes, those are the factory mudflaps. I never really noticed them much until you pointed them out. I think they aren't quite as noticeable in person.
Old Jul 6, 2009 | 07:31 PM
Dad's Avatar
Dad
Is there a blanking plate for the original 3rd light?
Old Jul 6, 2009 | 08:37 PM
Radsil09's Avatar
Yes. I got mine from Nissan as part of the spoiler kit. I'm pretty sure it comes seperate though.
Old Nov 24, 2011 | 05:37 AM
googus's Avatar
I have Ocean Grey which is the light blue. Did anyone leave their roof spoiler black from stillen or did everyone get theirs painted
Old May 9, 2012 | 02:50 PM
Stlbluzoo11's Avatar
What happened to these pics? I would like to see the stillen rear spoiler on the trunklid
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
ef9
Sep 5, 2015 11:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
jds22
Sep 4, 2015 01:52 PM
