Auto up and down windows stoped working after disconnecting battery
Old Jul 5, 2009 | 01:02 PM
IFuXwiTuZ's Avatar
Smile Auto up and down windows stoped working after disconnecting battery
ok well i decided to make this thread because this is something i just learned today and i thought i should share it with you guys....
i tried to install my sub and amp the other day and well i took apart my radio deck and unplugged the climate control and SRS airbag indicator..... after no luck with the system install (amp goes into safety when radio is set to 18...) I put everything back to the way it was and i noticed my SRS Airbag light blinking on front colum where the ODOmeter is....
so thinking that maybe unplugging my battery for like 10 minutes would reset the light...it didnt....
So after i put battery back i go to close my windows and the auto up feature didnt work...i was like WOWWWWWWWWWW what the efff is going on
so today i was like let me try something that i did to fix the auto sunroof on my dads mercedes.....
(make sure car is set to "on" the car doesnt have to be on just the button ignition set to "on")
keep in mind during this whole process you must hold the window button/switch (whatever its called) up and dont release untill you finish the 3 steps.
1. set ignition on "on" possition
2. hold the auto windows button up
3. while holding it up turn off the car
4. then put the ignition on the "on" position again while holding the the window thing up (hold for 5 more seconds)
put the windows down then bang all of a sudden my windows went up auto again and i was one happy camper but my srs air bag light is still blinking =(
i dont know if this made any sense to you guys...but hey it got my windows both driver and passenger side going up automatically again....
Old Jul 5, 2009 | 02:03 PM
09Maxima_Sam's Avatar
Yes, we knew about the window "Auto" function. Let us know what happens with your SRS light.
Old Jul 6, 2009 | 05:40 AM
MaxDOuT's Avatar
Make sure to do one window at a time or somehow if u do them all at on time the system gets confused and the windows will start acting up again.
Old Jul 7, 2009 | 08:12 AM
IFuXwiTuZ's Avatar
yes you are correct i forgot to mention that....hey max your car looks sick you got a cardomain page? ...i wanna see pics of it all around because im thinking of doing grill wet black and side chromes wet black....
Old Jul 10, 2009 | 07:56 PM
eldiente's Avatar
tried this, and now my passenger window is stuck half way up and won't move. any ideas? I guess I'll go try it again.
Old Jul 12, 2009 | 08:29 PM
eldiente's Avatar
I got the window working again but the auto up doesn't work on the passenger side.
Old Jul 12, 2009 | 08:46 PM
IFuXwiTuZ's Avatar
you need to hold up the window button fully turn car off then back on while holding the window button up fully
Old Jul 13, 2009 | 01:48 PM
eldiente's Avatar
I did that several times and the auto up still doesn't work. I didn't do it with the switch on the passenger's side only the driver side switch that controls the passenger side window. I'll have to try that next. if not I'll have the dealer look at it once a fix for the driver side seat movement is out and have em fix it then. thanks
Old Jul 13, 2009 | 02:08 PM
Mreim769's Avatar
Just hold the auto up when the car is on and the window is all the way up for like 5-6 seconds. Don't over complicate things by turning the car on and off.
Old Jul 16, 2009 | 07:23 PM
bk2k3max's Avatar
It's funny that you posted this thread because my Auto Up and Down feature stopped working after I installed my BD but I guess it wasn't due to the BD because I realized that at one point I did disconnect my battery but the even more odd thing is that now all of sudden my passenger side window Auto Up and Down feature has begun to work on its' own without me doing anything other than rolling the window up and down several times.
Old Jul 17, 2009 | 11:49 AM
eldiente's Avatar
That did work, just holding the button up for about 6 seconds did the trick. thanks
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
Superbform
Aug 11, 2015 08:10 PM
kenc15
Aug 5, 2015 08:29 AM
