20 inch rim help
Old Jan 3, 2010 | 08:16 PM
Antny74's Avatar
20 inch rim help
Ok guys I need your opinions. I just purchased a 2010 maxima in pearl white and I need to order a set of black 20s to replace the stock set. I can get a good deal on giovanna and gianelle wheels so I'm going to stick with those two brands ... the wheels below are the ones that I am trying to decide between. I also have the option to run non-staggered 255/35/20 tires on all four rims or I can do a staggered setup with front 245/35/20s and the rear with 275/30/20s opinions? Thanks in advance
Old Jan 3, 2010 | 08:29 PM
choice89's Avatar
I think any rim you select is going to look hot...but if I had to choose I would pick between the third set of rims you put up....just my choice. And I would also not do the staggered if you still want to be able to rotate your tires. I flirted with the idea when I got my 20's but I wanted to still be able to have a functional set of tires that would last a while and not being able to rotate tires on a front wheel drive car with staggered rims just does not make sense to me and serves no purpose but the look. I went back and forth on this concept but at the end of the day I kept functionality in front! Good luck on your selection and at the end of the day it is all up to what you want!!!
Old Jan 3, 2010 | 08:46 PM
Hpnotiq's Avatar
My vote is #1 or #4--BTW 2 & 5 look to be the same rim (unless I am missing something) can you confirm if they are the same & it was just a duplicate listing?
Old Jan 3, 2010 | 08:58 PM
KillaKam's Avatar
I think that any one that you go with would look good on the max... I would stay away from the first one IMO kinda looks like the stocks in a way to me IMO.
Old Jan 3, 2010 | 08:59 PM
Antny74's Avatar
they are the same design but (#2) is a 5 spoke setup and (#5) has 6 spokes
Old Jan 3, 2010 | 09:01 PM
Hpnotiq's Avatar
Oh ok thanks for pointing that out Ant.. Good luck with the decision
Old Jan 3, 2010 | 09:06 PM
Antny74's Avatar
No problem ... I just gotta make a decision soon and hopefully I will have pics for you guys within the next couple of weeks
Old Jan 3, 2010 | 09:41 PM
michaelle8885's Avatar
i personally only like the staggered set-up on coupes, and i say no to a staggered set-up on FWD, good luck bro.
Old Jan 4, 2010 | 01:17 AM
DJWILLIE's Avatar
Think they all look hot..good selection...
What are the weights on some of these do u know..?
Old Jan 4, 2010 | 11:53 AM
Antny74's Avatar
Not too sure man I haven't been able to find any weights online I'm sure I can call and find out, probably around 30 pounds or so?, btw I checked out your website, your mixes are crazy sick, keep doing it big! I will be reppin your work out here in vegas, LA and, SD
Old Jan 4, 2010 | 12:08 PM
Old Jan 4, 2010 | 05:27 PM
DJWILLIE's Avatar
Thanks I appreciate it -!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
Luigi623
Sep 21, 2015 01:42 PM
Serotta33
Sep 17, 2015 12:14 PM
