Suspension Creaking?
Hey guys. I have a 2010 Maxima S with an eibach pro kit.
My suspension recently started creaking at low speeds going over different road surfaces and when turning.
My best guess is that the springs are causing this? Is this an issue I need to get fixed or can I keep driving around?
Thanks in advance
Thanks in advance
This might be the famous front suspension recall a lot of people are talking about. I noticed it on mine (during slow turns, a small creak/pop on the left front side). According to the VIN number my car should not be affected but it sure sounds like the other users are experiencing.
Here's the official thread: http://forums.maxima.org/7th-generation-maxima-2009/599282-front-suspension-recall.html
I have an '10 that did not fall in that recall date either, but the noise seemed to progressively sound worse, so after showing the tech, they replace and that part has been fixed; I still have vibrations at highway speed(they did a force balance?) yesterday and it seemed to help a little, but i still see the passenger seat vibrating at certain speeds- so i will be going back again. I am really getting irritated with the dealer visits with this vibrating problem. I had an 07 that drove the way i expected this car to drive. bottom line is if they hear the clunking sound, they will fix it...
smarty- I did read about the tires, but did hope that the strut insulator and balance would resolve; so , I am calling and making an appointment tomorrow and will go from there. will let you know if i get any resolution, because I will keep going back until its fixed- at least that is the plan as of right now- cant see me dropping money for new tires on a brand new 37k car w/under 10k miles
I have had the car balanced on Hunter GSP9700 with straightrak twice and an all wheel alignment done and the vibrations continued. I'm pissed I spent the extra money on performance balancing and they still remain so balancing and alignments is not going to solve the problem. I can't speak for the strut insulators but I don't think replacing them will solve the vibration problems.
My Nissan stealership, though they were not going to help me, even came out and told me that the tires are the primary cause of the problems and that when customers paid to have Michelin Primacy's put on that the vibration problems went away afterward, but that they are not going to swap the tires for free, despite the fact others and two Nissan techs on here told me that some Nissan stealers are doing this!
heading out to my dealer this Friday am- talking with their manager(if that helps any?), but if you think that it is the RS-A tires currently on your car and not everyone else is having the same problem with their tires(and getting the michellins sounds pretty difficult) why not opt for a swap for a new set of RS-A tires? if the problem remains, then you can be fairly certain that it may be something else or just unlucky to have picked another set of problematic tires, but that is a minimal chance- anyway, i may opt for that course as they may be willing to go that route.
well I'm not the only one though on here going through this with vibration issues. The service manager at my local stealer even took me out in a new Maxima they just got in and the passenger seat vibrated and he is the one who told me that it all stems from the tires. Since it occurs on other Max's it can't be just from my specific tires. When I was in for an oil change on my Acura at my local Goodyear dealership, I asked them about the RS-A, and the guy told me that they have a enormous amount of people come in complaining about those tires and vibrations/shimmy and they typically recommend getting a different Goodyear tire that has less of that on it. Problem is, the the Eagle Responsedges are rated for noise and vibrations as well.
-- i am still going friday and will try my luck with this dealership and see what results i get-just cant see them balancing the car indefinitely
; any luck with changing PSI on tires???
funny thing is there were two silver '10 's on the lot and i picked the one with the funky tires
i am getting this creaking problem on my 2014 SV sport, ever since I had the eibachs put in. Is there a part number for the recall isolators? I doubt they will warranty it since I have the drop springs I will just get the isolators put on if it will fix it.
Welcome to the eibach spring creak club. This has happened to a lot of us. The springs are progressive so the first spring rate is soft. If you look at the springs the coils are bottomed out on each other and when you turn the wheel they "bind and release" on each other. I found that if I out my car on a lift to take the load of the suspension then I grabbed the spring and rotated it a half inch a way from the stop on the perch. I then used some spiral wiring loom to cover the rear of the coils that could touch. I then used a slight layer of bearing grease to lube the coils that touched. The sound went away. It drove me nuts until I figured that out. Give it a shot.
I was looking at my stocking springs, and it looks like there was something that would cover certain coils, it isn't there anymore so I'm guessing they swapped it to the eibachs. I'm going back to the shop and am going to have them make sure the springs are seated correctly, and lube the springs. I'll grab some wire loom to bring them too, just in case.
I thought there might have been because I thought it was a tsb for the older 7th gens. So wire loom is fine it will last? Or did eibach forget something in my spring box? When you had the problem it was kind of like a popping you could feel thru the steering wheel?
Thanks Abe for the great info, I am going to give my mechanic your suggestions. I'm so glad I found out what the problem is, having suspension noise on a brand new car is driving me nuts! I will post up the results after I go back to the shop.
I brought it back to them, they said the strut bearings are fine since the car has only 10k miles on it. They put the spiral loom on which made it a lot better but it's still doing it a little. I am just going to bring it to nissan so they can figure it out I guess
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
