Traction Control and E-Brake lights randomly coming on
Old Feb 10, 2011 | 08:01 AM
Ghozt's Avatar
Anyone else an issue with the traction control (VDC) light and/or the e-brake light coming on randomly while driving? Seems to have started happening after I used tap-in connectors to connect my load resistors for the LED turn signals. Hesitant to take it directly to Nissan just yet cause I have a feeling they'll tell me to take that stuff off. Any idea what I can check, or if you don't think it's related?
Old Feb 10, 2011 | 10:18 AM
MAX1MKA's Avatar
i do have the same thing going on and i didnt connect anything lol and i been told that it may be some sensor acting like after the snow
Old Feb 10, 2011 | 12:06 PM
TBA's Avatar
TBA
Check your brake fluid level and top off if low. Several members, including myself, had the same issues. Topping off the brake fluid resolved it.
My symptoms were also random at first, then a pattern become evident; the lights would come on more during turns and dips (where the fluid would slosh in the reservoir).
FYI, the owner's manual says one cause of the BRAKE light being on is low brake fluid.
Old Feb 11, 2011 | 12:26 PM
krup27t's Avatar
Having the same problem bringing it in to nissan on monday
Old Feb 11, 2011 | 12:28 PM
Ghozt's Avatar
I'm going to try to top off the brake fluid, but let us all know what Nissan says about your problem please! It's not a big deal but I would like it to be working correctly.
Old Feb 11, 2011 | 08:07 PM
Lanzz's Avatar
same issue with mine - dealer said pads were fine - topped off fluid and no more issues.
Old Feb 11, 2011 | 08:38 PM
lightonthehill's Avatar
This happened once with my car about two years ago (when it was fairly new). Has not happened since.
Old Feb 11, 2011 | 10:50 PM
KillaKam's Avatar
Its your brake fluid; basically what it means is that its time for a break job....
Old Feb 12, 2011 | 12:11 AM
That would normally be the case. But most of these 7th gen Maxima incidents happen the first year of the car's life, and once fluid is added, do not happen again.
Mine happened just like Lanzz's (3 posts back) did, with no brake pad problem involved. My pads were only a month old when it happened, and still have very little wear two years later. I usually get between 50K and 60K miles on my Maximas before needing brake work.
There is something in the brake system of these 7th gens that expands or changes in a way that allows the fluid level to sink with no wear on the brake pads involved. But once fluid is added the first time, the problem does not happen again.
Old Feb 12, 2011 | 09:59 AM
Ghozt's Avatar
I'm guessing brakes pads/rotors aren't covered by warranty since they're wear and tear? I'll probably just take it to my personal mechanic then and have him do the work if I need anything beyond brake fluid.
Old Feb 13, 2011 | 03:58 PM
Unless something goes wrong the first 12K miles, brake pads are rotors are generally considered 'wear and tear' items.
Unless you are driving in city traffic, or are hard on your brakes, you shouldn't have to do any major brake work the first 40 to 60K miles. I usually have to have mine reworked around 55K, but then I am easy on my brakes.
Old Feb 13, 2011 | 07:59 PM
Ghozt's Avatar
I'm ~25,000 miles, should I just have to do brake pads? I've read a few other threads on here where members say their back brakes went out prematurely because this car is designed to brake more with the back axle to prevent nosediving or something. My mechanic said my back brakes would need work soon when he inspected the car for me so I assumed he meant brakes/rotors but if it seems early for rotors I'll hold off on buying the replacement parts. Was gonna just order some rear rotors/pads now so I had them ready.
Old Mar 10, 2011 | 01:09 PM
1sik4dsc's Avatar
same thing is happening to my car now, Im going to top off the brake fluid hopefully it works, seems like thats the fix
Old Mar 10, 2011 | 03:35 PM
Maxima-2's Avatar
+1 exact same deal. Noticed it first a couple weeks ago when i was spinning and the lights stayed on went off after a restart this happened twice. Since then it has occured again under normal driving conditions. Plus my EBC redstuff pads will be here tomorrow.
Dan
EDIT: WHO WANTS TO MAKE ME A NEW SIGNATURE? lol.
Old Mar 15, 2011 | 03:33 PM
Ghozt's Avatar
Thanks guy, you nailed it. Topping off the brake fluid fixed the issue with these lights coming on. I'm at ~25,000 miles but my rear brakes sometimes make a noise now and they needed servicing soon so I had them machined and installed some EBC greenstuff pads on both rear brakes. Still in the break-in period so haven't had a chance to really test the new pads but just loving that the lights went off so far.
Old Oct 12, 2011 | 03:46 PM
daleschott's Avatar
I have the same problem. just started about 3 weeks ago. The dealer ship was no help, as the light had gone out and the computer did not show a record of the light being on. searching in internet give a little information. seems we may have low brake fluid, mine show just above minimum.
can anyone tell us if that is a fix?
Old Oct 12, 2011 | 04:08 PM
If your brake fluid is just above minimum, then that will soon be causing the VDC and brake warning lights on your dash to light up, and may well be what is causing them to light up already.
Bring the brake fluid level up to the full mark (I always try to keep mine at or near full), and I bet your problem disappears.
Old Jan 13, 2015 | 05:22 PM
Stelianos's Avatar
Yup, that did the trick for me. I was extremely skeptical as my reservoir was half way between min and max but it worked. Good job guys 👍
Old Jan 8, 2016 | 11:20 AM
Sigs_93c's Avatar
Hey guys I'm new to the site. Wanted to let you know, my brake fluid was down to the low line, and once i filled it up it was G2G. Thanks for the help!
I have a 2011 SV with 56K
King_Ten_Ahead
Sep 30, 2015 04:27 PM
schmellyfart
Sep 25, 2015 04:47 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
MikesChevelle
Aug 6, 2015 11:36 AM
