Cutting plastic covers in engine bay for strut bars
Old Mar 16, 2011 | 04:41 PM
Ghozt's Avatar
I've had my Racingline strut bar in for a while now but never re-installed the black plastic covers because obviously the strut bar is in the way. I wanted to make sure I didn't cut more than I need to, I want this as flush as I can get it to the strut bar if possible.
I was wondering if anyone else has cut their covers and has a nice fit and wouldn't mind taking a tape measure and getting me some measurements of where the cuts you made are and how long they are?
Also what'd you cut the covers with? A jigsaw? A razorblade? A dremel? What would give the cleanest looking edge?
Old Mar 16, 2011 | 09:21 PM
bigear82's Avatar
Jigsaw didn't work for me. Razorblade may take some time. Dremel may work for you here.
Old Mar 17, 2011 | 03:01 AM
Max_Sleeper's Avatar
Exclamation
I took em out and left them out... they are pointless... just meant to scare the average guy away from doing ANYTHING to their car
Old Mar 17, 2011 | 05:54 AM
mrodenberg0124's Avatar
If i ever get my order from Racingline i'll let you know... heh
Old Mar 17, 2011 | 06:13 AM
I am in NJ and got my order in 10 days from Racingline. Strut Bar looks great.
Old Mar 17, 2011 | 07:05 AM
Ghozt's Avatar
I think the engine bay looks a heck of a lot cleaner with them on. I know several people have cut theirs around the strut bar so just hoping someone either has the measurements or feels like taking 60 seconds to look at theirs and help me out.
I got my Racingline Strut bar pretty quickly, but I heard a bunch of people ordered the Sway bar and are still waiting months later...
Old Mar 17, 2011 | 07:28 AM
I'm at... over 5 weeks now... Then again everything i ordered was out of stock at the time... rear sway... front endlinks... rear endlinks.... I think maybe the front strut was in stock... maybe... At least they were nice enough to take $30 off the rear sway for the wait.
If you still need measurements when i get mine in i'll shoot them at you.
Old Mar 17, 2011 | 07:59 AM
bigear82's Avatar
I put my covers back on because my engine bay was getting dirtier inside since the covers weren't there.
Old Mar 17, 2011 | 08:05 AM
Kmoney's Avatar
It be hard to get measurements. I got the stillen one and you just need to put the cover on n mark where need to be cut.. well that's what I did n came out nice
Old Mar 17, 2011 | 08:07 AM
Damn thats a long time I would be pissed.... but if you ever get it let me know how the rear sway helped
Old Mar 17, 2011 | 08:18 AM
I am thinking about doing some dressup stuff under the hood ad considered painting under there... just a thought for now ... I love opening a hood and seeing some flashyness
Old Mar 17, 2011 | 08:29 AM
MadMax07SL's Avatar
Dremel with a wheel will probably do the trick. cut from the top, and smooth the edges when you're done.
What do you need measurements for? Put the bar in, lay the panel back on, and use masking tape and a sharpie to draw out your cut pattern...
Old Mar 17, 2011 | 08:52 AM
G09madmax's Avatar
check this thread, you'll see some examples; http://forums.maxima.org/7th-generat...p-7th-gen.html
(mine is on there too, a shop had did mine, didn't like so i bought a new one and re did it my self, like that last kat said, use duck tape and a marker
Old Mar 17, 2011 | 09:27 AM
bigear82's Avatar
Old Mar 17, 2011 | 12:03 PM
Ghozt's Avatar
I already installed the strut bar so it's hard for me to see exactly how far IN to the piece I need to cut. I can see roughly where I cut into the edge to start, but again am not sure how far IN (to the sides) to go and don't want to cut too much and have a bunch of gaps around this stuff. Maybe I'm being particular but I did want to do it as clean as possible and don't see a way to get exact measurements other than taking the strut bar back off and lining it up with the plastic pieces before I install.
Maybe I should just be extremely conservative and cut way less than I know I need to and just keep edging it out until I have a perfect fit. Just basic fine sandpaper to smooth the edges out I guess? Sorry I haven't worked with much plastic before, at least not that I wanted to look nice after I was done with it.
Old Mar 17, 2011 | 12:15 PM
Kmoney's Avatar
The only way u can cut it is to first install it. U Can never get an accurate cut. One way or the other, u will cut a little piece over.
Old Mar 18, 2011 | 02:45 PM
Glenns25's Avatar
I cut mine with a dremel cut off wheel.
Old Mar 18, 2011 | 03:30 PM
Ghozt's Avatar
Hmm. Maybe I should just plan on overcutting and then putting something black and soft inbetween the two to fill the gap, like maybe a sliced black rubber tube or something. Or maybe I should stop caring so much about an area of the car people barely ever see...hahaha...
Old Mar 21, 2011 | 05:16 AM
Juggernaut23's Avatar
Anyone who has vut theirs care to snap some pics of them on and off and post them so others can see it and copy them?Since measuring is a PITA a few snap shots and a guesstimate would be a big help for others. I used a dremel to cut mine and a razor to shave a nice edge on them.But I think I could have done a little better of a job.
Old Mar 21, 2011 | 06:29 AM
MadMax07SL's Avatar
I already installed the strut bar so it's hard for me to see exactly how far IN to the piece I need to cut. .
It's what, 3 bolts on each side...remove bolts and bar, put cover on one side, install bar on bolts on opposite side hand tight, strut bar will lay on cover, and you can trace it (masking tape on top of cover, sharpie around strut bar). Then you'd make minor adjustments depending on how small you want the hole to actually be.
...I'd have to presume that's the easiest way to do it...
Old Mar 26, 2011 | 09:49 AM
Ghozt's Avatar
I figured out a good way to get some measurements and got a great cut out on the driver side plastic piece. Problem is because the Racingline bracket is so tall it still pushes the plastic piece upwards in the front and looks kind of stupid. My cut has already gone into the piece sideways several inches and I'm starting to get the feeling I'm going to have to cut pretty deep into the piece to let it sit with the Racingline bracket well. The Stillen one looks much easier to cut for...
Old Sep 6, 2011 | 07:32 PM
Glockman40's Avatar
Leave them off who cares. You'll drive past a millions of people that won't see it and maybe show only 20 people that you know.
Old Sep 6, 2011 | 08:13 PM
Ghozt's Avatar
i figured it out
also - ive shown more than 20 people
Old Sep 7, 2011 | 02:32 AM
STARR's Avatar
Originally Posted by Ghozt
i figured it out
How did you do that, they look perfect and recessed
Old Sep 7, 2011 | 04:37 AM
funnyman82's Avatar
those red covers look awesome!!!
Old Sep 7, 2011 | 05:02 AM
Ghozt's Avatar
I took the strut bar off, put the engine covers back on with some painters tape on the top. I then set the strut bar where it goes when installed and traced the ends. Took a dremel and about 15 minutes to cut/sand it down for a smooth edge.
Old Sep 7, 2011 | 06:30 AM
eesjunin's Avatar
Strut bar looks great...but what in the world did you do to the plastic?...
i figured it out
Old Sep 7, 2011 | 06:44 AM
Ghozt's Avatar
see the notches cut out of the corner plastic pieces so the strut bar can fit? had to cut those notches out otherwise the plastic covers don't fit back in
Old Sep 7, 2011 | 07:12 AM
eesjunin's Avatar
I know that part looks great...i was talking more about the color of the plastic protectors...dont tell me it came that color
Old Sep 7, 2011 | 08:41 AM
Ghozt's Avatar
if it came that color yours would be red too. first paint project ever, came out amazing considering ive never painted before.
Old Sep 7, 2011 | 08:52 AM
GM_Traitor3.5VQ's Avatar
Red makes the car go faster... everyone knows that!
Old Sep 7, 2011 | 08:56 AM
Ghozt's Avatar
well it was a given that the red added 15 HP at the wheels. KMoney said his blue added 20 but red is my favorite color so
Old Sep 7, 2011 | 09:00 AM
like my red GTR button added 200! Bahahaha. I'm actually tempted to have someone paint my engine cover in the factory RAB navy blue with a gel-coat so it looks smooth as glass. Entire engine bay is black... needs SOME color to offset it all
Old Sep 7, 2011 | 09:28 AM
eesjunin's Avatar
Thats it? i expected more...little dissapointing Gents
Old Sep 7, 2011 | 09:32 AM
eesjunin's Avatar
Weird it didnt take what i typed...
I did this on my benzo...but not to the extreme that you went!
The beauty is int he eyes of the beholder! So rock on!
Old Sep 7, 2011 | 11:17 AM
Ghozt's Avatar
yeah i know some people think it's ricey but its all good. not like id ever pop the hood and have a turbo or supercharger under there so my options were a few bolt-ons and some paint lol. honestly the red came out way brighter than i was expecting, but its all gravy
Old Sep 7, 2011 | 12:24 PM
I have another idea for your engine cover that still incorporates the red color. Could do something similar to the Nismo 370 engine cover?
Old Sep 7, 2011 | 12:44 PM
eesjunin's Avatar
BTW what kind of CAI is that?
Thanks!
i figured it out
Old Sep 7, 2011 | 12:46 PM
Thanks!
Custom true CAI he built himself. He has a thread on how he built it (materials, pipe lengths, etc) in the 7th gen forum.
Old Sep 7, 2011 | 01:21 PM
eesjunin's Avatar
In my eyes this looks very settled and not that "bright"
