OEM Part # for tire pressure sensor ?
Old Nov 21, 2011 | 05:46 PM
wope's Avatar
Does anyone know if part # 40700-JA01B is the correct sensor for a 2010 Maxima? I ask because I've been able to confirm it works on 2009 Maximas, but nothing concrete no 2010s.
Also, do you know if I will need anything else besides 4 of these to install them? Any sort of install kit or something? Planning on adding TPMS to my aftermarket wheels.
Thank you.
Old Nov 22, 2011 | 03:25 PM
MaxLoverAz's Avatar
Thank you.
No kit but you'll either need the dealer or a good tire dealer to reprogram the system to accept your new sensors.
Nissan uses Schrader TPMS sensors, when the TPMS system is fitted at the factory the unique ID numbers of the TPMS sensors have to be registered along with their position on the car with the tire pressure monitor ECU. This is also the case if any of the system components are subsequently changed e.g. in the event of changing sensors, replacing the ECU etc. This process requires the activation of the TPMS sensor using low frequency radio and the capture of the UHF data transmitted. This data includes the TPMS ID, the pressure and temperature.
In the factory the activation is carried out using large antenna systems on the production line but in the dealerships and tire shops hand tools are used.
If a TPMS sensor is changed without re-registering the IDs then the TPMS warning light will turn on and stay on until the ID's are re-registered.
You can also get these as this is the OEM manufacturer:
http://www.amazon.com/Schrader-AirAw.../dp/B002GYSR9E
Maxboy23
Sep 8, 2015 06:53 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
gizzsdad
Aug 19, 2015 01:01 PM
doobadoo
Aug 15, 2015 06:43 PM
