$176 for a transmission fluid change??? Alternative options?
Old Jan 18, 2014 | 08:32 AM
  #41
mjtct's Avatar
< ON-VEHICLE MAINTENANCE > [CVT: RE0F09B]
Check CVT fluid condition.
• If CVT fluid is very dark or smells burned, check operation of CVT.
Flush cooling system after repair of CVT.
• If CVT fluid contains frictional material (clutches, brakes, etc.),
inspect and clean the CVT fluid cooler mounted in the radiator and
flush cooler line using cleaning solvent and compressed air after
repair of CVT. Refer to TM-154, "Cleaning".
Changing INFOID:0000000003900188
CAUTION:
Replace a O-ring with new ones at the final stage of the operation when installing.
1. Remove drain plug from oil pan.
2. Remove O-ring from drain plug.
3. Install O-ring to drain plug.
CAUTION:
Never reuse O-ring.
4. Install drain plug to oil pan. Refer to TM-174, "Exploded View".
5. Fill CVT fluid from CVT fluid charging pipe to the specified level.
CAUTION:
• Use only Genuine NISSAN CVT Fluid NS-2. Never mix with other fluid.
• Using CVT fluid other than Genuine NISSAN CVT Fluid NS-2 will deteriorate in driveability and
CVT durability, and may damage the CVT, which is not covered by the warranty.
• When filling CVT fluid, take care not to scatter heat generating parts such as exhaust.
• Sufficiently shake the container of CVT fluid before using.
• Delete CVT fluid deterioration date with CONSULT-III after changing CVT fluid. Refer to TM-35,
"CONSULT-III Function (TRANSMISSION)".
6. With the engine warmed up, drive the vehicle in an urban area.
NOTE:
When ambient temperature is 20°C (68°F), it takes about 10 minutes for the CVT fluid to warm up to 50 to
80°C (122 to 176°F).
7. Check CVT fluid level and condition.
8. Repeat steps 1 to 5 if CVT fluid has been contaminated.
Fluid status Conceivable cause Required operation
Varnished (viscous
varnish state)
CVT fluid becomes
degraded due to
high temperatures.
Replace the CVT fluid and check the
CVT main unit and the vehicle for
malfunctions (wire harnesses, cooler
pipes, etc.)
Milky white or
cloudy
Water in the fluid
Replace the CVT fluid and check for
places where water is getting in.
Large amount of
metal powder mixed
in
Unusual wear of
sliding parts within
CVT
improper operation of the CVT.
ATA0022D
CVT fluid : Refer to TM-186, "General Specification".
Fluid capacity : Refer to TM-186, "General Specification".
TM-154
CVT FLUID COOLER SYSTEM
Cleaning INFOID:0000000003900189
Whenever an automatic transaxle is repaired, overhauled, or replaced, the CVT fluid cooler mounted in the
radiator must be inspected and cleaned.
Metal debris and friction material, if present, can be trapped or be deposited in the CVT fluid cooler. This
debris can contaminate the newly serviced CVT or, in severe cases, can block or restrict the flow of CVT fluid.
In either case, malfunction of the newly serviced CVT may occur.
Debris, if present, may deposit as CVT fluid enters the cooler inlet. It will be necessary to back flush the cooler
through the cooler outlet in order to flush out any built up debris.
Old Jan 23, 2015 | 10:16 AM
  #42
bluefish7's Avatar
Drain washer
There is a crush washer that needs to be replaced? Anybody know what size? Thanks
Old Jan 23, 2015 | 11:08 AM
  #43
chiefy's Avatar
only reason i changed mine at 45k was because i drive real hard and have a long commute everyday. but purchased off ebay and easier than regular oil change
Old Jan 23, 2015 | 01:02 PM
  #44
maxud's Avatar
you can reuse this washer many times. As long as you don't over-tighten it, you will be fine.
If you go by the book, it will tell you to replace it, but trust me, you will be fine.
Max
Old Jan 23, 2015 | 03:35 PM
  #45
Maxgig's Avatar
I changed mine at 50k and will do it again at 100k. I checked my dealership first and they quoted me a price around $300. I used their NSN numbers off my service receipt and ordered my fluid from eBay. Everything cost me around $130, I had the peace of mind knowing that I had did it myself and felt good saving over $100+ dollars.
Old Jan 23, 2015 | 10:15 PM
  #46
MaximaDrvr's Avatar
The cvt trans have been known to have problems.
They usually say it only needs to be changed after 100k, which is conveniently when any extended warranty coverage is also over.
I drain and fill mine every 30k, and have since 60k miles. I can feel a difference every time it is done. I'm at 125k and still going strong. My dealer charges me $150 for the service.
Old Jan 23, 2015 | 11:34 PM
  #47
Texakinz's Avatar
I bought the trans fluid from dealer for $120 (6qrts) and had a mechanic change it for $30. Just drain and fill.
Old Jan 26, 2015 | 06:27 PM
  #48
sonomamax's Avatar
cvt
I dont know why some people would use something in that isnt authorized, those things are expensive, You buy a 45k car and then want to spend little or nothing on cvt fluid. And being changed after 60 or 100000 miles is a long time, that is just pnuts to spend.
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
