R2C racing intake system
Whats up fam,
I just installed the R2C racing air intake system after removing the Stillen intake that gave me nothing but problem since day one. Constant engine lights and now that I put the R2C it's unreal what a differance in sound an torque day & night highly recommend it especially when it just cost me $229.00 shipped right from the R2C website the other site try to charge u $300 +. But much respect to Stillen for honoring there products for real I had this intake for over a year now and they told me to send it back for a full refund WOW! U gotta respect that not to many company will do that for u.. But overall I just had to post about this intake sounds great & u definitely feel the power differance.
Pretty interesting. Nice review. Anyone else have this intake on their maxima?
http://www.r2cperformance.com/nissan...ke-system.aspx
Checked out the site just now. I like how the cone air filter is oil-less and that this intake design also uses the stock forced air tube.
Their site has some dunk sheets comparing stock vs theirs. Decent gains... But how reliable is their dyno of the CVT?
Yes it threw up codes on the regular extremely annoying and I've been installing intakes for years and never had any issues with codes. Also I guess that they have many other complaints cause when I called them to address the issue they had told me that there were several complaints. They actually sent me a mass airflow sensor spacer thinking that it would sve the problem and guess what? It didn't and I also sent them the codes from when the dealer printed out for me..
Actually it was incredibly easy to install also they took the extra thought into placing a hole for when u place the mass airflow sensor in place it clips right in Nice! The Stillen was a pain in the a$$ because the way the mass airflow was pivoted so u needed to get a small screwdriver in order to tighten the screw blows.. I also like how it isolates the heat from the filter very nice and the other great feature is that with this intake u can just change out the filter really easy oppose to the Stillen u would have to take it all apart and not to mention need a direct replacement because if u notice the filter isn't like the other ones it's made to just work with the Stillen intake alone Because I wanted to get a weapon R filter and it would fit..
I always wondered why they just didn't give the box a complete seal to the hood insulation.
I ran Takeda and R2C before building a true CAI and both short rams were almost identical to each other in terms of noise they made. Noticed slight power bump in upper power band, but lots of heat soak when idling. A few people have issues with the R2C filter falling off while driving, probably because it is so freakin enormous. For those curious, the ridiculous looking "heat shield" included does nothing to prevent heat soak, as mentioned above it is not a complete shroud.
If you want to see all the testing I did on the R2C intake vs the true CAI feel free to check out this thread here.
http://forums.maxima.org/7th-generat...ustom-cai.html
Sorry bro, I have no interest in building a CAI for mass production, I just made one for myself and did testing to show everyone what a short ram is actually doing for your engine. Most people slap them on and think their car is a race car cause it makes more noise.
I'm sorry if my testing offended you and your short ram intake, it doesn't change how the temps are in real world testing. Even my stock intake provided more power/MPG than the short rams. And yes lots of people "think" these short rams are awesome.
yea the 6th gen Maximas have a thread on it, they did back to back comparison of stock vs SRI and short ram pulled better low and mid range and had better mileage. you forget that the stock box on ours has a nice tight seal with the oem grill duct and it pulls air from there nicely. whoever can figure out a SRI with a complete shroud that matches up to the OEM grill duct like the stock one will be the winner.
I'm probably a bit older than most here but I just sit back and listen, ask questions, learning a little and experiment.
Use to bracket race some back in the 80's/90's. Tech has changed so much but most of the same principles apply to this car.
With time, I'll bet some of you young guys will probably learn and crack things like the current CVT limitations.
Just look on this site, a lot of new stuff is being developed by max owners like you.
Thanks alot for the info!
Know what your talking about, been there, and I'm always tempted. Remember patience usually pays off big time $$$.
Same here - just sitting back watching and learning. I was originally looking at the K&N Typhoon but didn't like the idea of having to oil the filter. I couldn't find the dry filter to go with it. So I started looking at the Injen and R2C. I settled on the R2C but decided to do one more search for the K&N dry filter. Amsoil makes one that will fit the Typhoon so I'll be getting the K&N some time in the next few weeks.
The stock Nissan filter it replaced appeared quite saturated with oil compared to the K&N, almost acted more like a plug than a true filter.
The car really came to life with both the y-pipe/K&N upgrade.
Between Ghozt and I, we're data logging the different intake systems like crazy. Once I get everything together, I'm tempted to create an intake thread showing the comparisons between the popular SRI setups for our cars.
That would be great. I'm really interested in the difference between the stock box with K&N Panel and an SRI. Is there a difference at all? Is it worth $200? What about the sound?
You'll definitely get more sound with any SRI setup, however most gearheads know that sound doesn't always equate to horsepower
You'll gain some ponies up high in the rev range and more sound for sure. I wish we had the option to improve the stock airbox setup like the G37/370Z guys do. Mishimoto post-MAF tubes and K&N panel filters are VERY popular with those guys instead of spending $600 on the Stillen Gen-3 longtube CAI setup.
