Hids do not work
Old Jun 2, 2012 | 03:12 PM
rooneynguyen's Avatar
Hids do not work
Hello, maxima owners,
I recently bought an HID kit 6k from xenon supply. There was no relay...just a standard bulb,ballast and connectors.
I worked on the car today replaced the old bulbs with the HIDs but it did not power up....i tried switching polarity but did not light up...so i quit and reinstalled my old bulb with no problem
Do i need a relay to make it work? do u guys have a relay?
Old Jun 2, 2012 | 04:03 PM
madmax17's Avatar
The relay is usually recommended, but not required. I installed an HID kit last month and I did not use the relay harness and its been fine.
Did you try both bulbs and ballast? Maybe one of the ballast/bulbs is bad.
Old Jun 2, 2012 | 04:08 PM
Yes, i have tried both none of them light up, i bought these at a reliable website online *xenon supply" but it did not light up....i do not know what is wrong the HIDS are 35 watt 6k....
Old Jun 2, 2012 | 04:11 PM
madmax17's Avatar
That's weird that they both didn't light up. The only other thing I could think of was to switch the polarity but you already did that. I would definitively contact Xenon Supply to see what they recommend
Good luck
Old Jun 2, 2012 | 04:20 PM
Try testing them directly off the battery. If they work like that then you're doing something wrong during installation. If they still don't work that way, then you've got defective HIDs.
Old Jun 2, 2012 | 05:00 PM
PetitFrereMaxima's Avatar
I guess bulbs might be defective. I am sure you will get replacements or your money back. I hope everything works out for you.
Old Jun 2, 2012 | 09:31 PM
Guys, i posted pics of how i connected this....this is how right?
http://i47.photobucket.com/albums/f1...74903073_n.jpg
Male and Female
http://i47.photobucket.com/albums/f1...00190395_n.jpg
Ballast connection
The whole thing
http://i47.photobucket.com/albums/f1...38659450_n.jpg
Old Jun 3, 2012 | 03:55 AM
funnyman82's Avatar
I had a similar issue when I connected my new ballasts... My problems was the connection to the oem wiring. At that point there was a little nub or something that prevented the connection to be made properly. It looked like it was fine but took a reasonable amount of force and shaving down the nub to make it work.. Hope it helps...
Old Jun 3, 2012 | 03:56 AM
funnyman82's Avatar
Btw I was doing my fogs...
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
