Help cleaning the glass over the Gauges!
Nov 24, 2012 | 03:50 AM
Hey guys,
When I bought my 09 Maxima there were these weird stains/dirt marks on the inside glass of the gauges. I took pictures as best as I could but can anyone tell me if there is an easy way to get inside of there and clean it off? The help would be much appreciated! Thanks
Nov 24, 2012 | 06:45 AM
If the dirt is from inside then the dash must have been taken apart before. Did you buy the car new ?
Nov 24, 2012 | 06:57 AM
you can remove a couple dash trim pieces and get the cluster out. the plastic cover on the cluster pops off and you can clean behind it. the question is, like the other guy mentioned, did someone else open this up before? thats the only way crap would get in there
Nov 24, 2012 | 09:26 AM
Looks like someone has got Armor All or something like that on the lens. That will stain the lens also. Did it to a truck I used to drive accidentally.
Nov 24, 2012 | 11:55 AM
No I didnt buy the car new so maybe someone else has gotten in there. Yea Im gonna have to make sure that it not armor all or something. Is it difficult to take the trim pieces off and get behind the cluster?
Nov 24, 2012 | 06:43 PM
Make sure you use a high quality microfiber towel on the glass! I love Invisible Glass...it works very well for me.
Nov 24, 2012 | 08:01 PM
Quote: No I didnt buy the car new so maybe someone else has gotten in there. Yea Im gonna have to make sure that it not armor all or something. Is it difficult to take the trim pieces off and get behind the cluster?
difficult no, but you do have to do it in a certain order (take off side trim piece that you can only see when doors open first, this gives access to removing the rest). when you get the main dash piece off its a few screws and you can pull the instrument cluster forward, then disconnect it from behind. definitely try cleaning off the front of it first, you can use Plast-X which is great for removing garbage from plastic. if you need to get in there though to clean the inside it isnt terribly complex, hit me up if you need some help
Nov 25, 2012 | 12:02 PM
Thanks for the help
Nov 25, 2012 | 12:49 PM
such a good question! i've always wondered how to clean this on my nissan!
Nov 26, 2012 | 08:55 PM
i have the same problem bought the car new 2
i used all kinds of cleaners and no luck but will try plastX next
