Suspension Squeak
Old Nov 26, 2012 | 10:14 AM
jrodman's Avatar
Suspension Squeak
Hey Guys, your help is much appreciated here.
I just bought a certified, pre-owned '09 Maxima SV with 30K miles on it. The car is flawless other than a minor suspension squeak that I think is coming from the rear of the car when I go over potholes or and the like. Is this something that I should take the car into the dealership for them to take a look at? Or, is it something native to the car and I just have to deal with it. I simply hate not knowing whether there is something wrong. A family member of mine owns the dealership where I purchased the car and I am sure they would be happy to take care of it if you guys suggest that I take it in.
Thanks again!
Old Nov 26, 2012 | 10:28 AM
MaximaGuido09c's Avatar
Being that a family member owns the dealership..Why wouldn't you take it in? I had the same problem..but Nissan are a bunch of idiots, So I swapped out the suspension with Eibachs..Problem disappeared after that!
Old Nov 26, 2012 | 08:22 PM
TBA's Avatar
TBA
There were two technical bulletins for rear suspension squeaks for that yeanrelated to the sway bar bushings. The first called for the rubber bushing to be removed and lubed. The second called for replacing the squeaking bushings with a new design.
I would got back and have the dealer install the new bushings. They can look up the tsb for the parts, etc.
Old Nov 27, 2012 | 04:29 AM
newsat65's Avatar
Yup!!!!!!
Old Nov 28, 2012 | 05:51 PM
Max2000SE's Avatar
I had this done on mine last winter, havent had a problem since. Had to take it back twice prior to that, but that was what the TSB stated, first they lube them up, then if it still continues they replace them. good luck
Old Nov 28, 2012 | 11:04 PM
Area502's Avatar
I seem to have that same prob, same year too
Old Nov 29, 2012 | 02:03 AM
shep1sean's Avatar
me too. i,m having it now actually.. when i took mine to the dealer i couldnt get my car to make the noise about two months ago. but its doing it now. help me out. take it to the dealer and what should i say about a TSB?
Old Nov 29, 2012 | 04:17 AM
Ryan31's Avatar
I too have the dreaded suspension squeak. I've brought it in and they replaced rear bushings from the TSB. It did not help it at all.
I notice it at slow speeds going over dips in the road. Speed bumps its very noticeable.
I'll mention it again at my next oil change.
Old Nov 29, 2012 | 05:14 AM
09max_sv's Avatar
Ive had this since I installed the Racing-line rear sways bar. You guys talk about squeak, lol, every little bump it speaks..
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
