DIY : How to Install Illuminated Kick Plates
Thanks to Dom (2themax11) for jumping on top of these as soon as they were available and grabbing me a set, you're the man! We both have ours installed now and love them! If anyone is interested contact Matt Keevan at parts@nissanaccessories247.com for more information. Join our FB group for a special coupon code you can use for 5% off purchases.
This guide is primarily directed at the 09-11's who will need to splice into the foot wells for lighting. If you have a 2012 these plug directly in and you can download install instructions from most of the Nissan parts websites. I kept the steps easy and materials simple so anyone can do this and reverse it later if they want, however soldering is the preferred method to extend wires. Most of these instructions will also apply to Deadbolt's custom illuminated kick plates that he makes; hit him up if you want custom wording/colors. Tools: Pliers, wire stripper/cutter, butter knife/plastic trim removal tools Materials: 2012+ illuminated kick plates, 4 tap-in connectors (18-24 gauge), 2-4 wire screws, about 4-8 inches of any wire Step 1. Open up the box https://lh4.googleusercontent.com/-i...313_111144.jpg I hooked them up to a power supply to test; nice looking. https://lh5.googleusercontent.com/-h...313_130824.jpg Step 2. Remove existing kick panels, I slid my tool under them until I hit a clip then applied upwards pressure https://lh5.googleusercontent.com/-J...313_175955.jpg Step 3. Pry off trim piece directly next to it. Start by pulling it towards the chair to release inner clips, then pull upwards to pop off https://lh3.googleusercontent.com/-2...313_180009.jpg https://lh6.googleusercontent.com/-m...313_180017.jpg Step 4. Cut off the brown plug from the kick plate wiring, trim back the plastic sheath several inches. https://lh6.googleusercontent.com/-E...313_180220.jpg Step 5. Install new kick plate, it pops right on. Run the wire through the plastic rings towards the front under the dash and have it pop out from underneath https://lh3.googleusercontent.com/-x...313_180340.jpg https://lh6.googleusercontent.com/-5...313_180433.jpg Step 6. Extend the wires for the passenger side. You can do this for the driver side as well for more slack but I didn't need to. Here you can use the wire nuts as this guide indicates, or simply solder on roughly 4" extension to both the positive and negative wires. Only strip the wires where you're planning on using the twist wire caps. https://lh3.googleusercontent.com/-W...313_181730.jpg Step 7. Unscrew bulb from dash, creating slack on the OEM wires to work with. Use the tap-in connectors to splice the red wire from the kick plates to the pink wire of the floor lighting. Squeeze the tap-in connector with your pliers to smash the metal blade and connect the wires. Use the same method to splice the black wire from the kick plates into the yellow wire from the floor lighting. Do not strip wires for this, the tap-in connector is designed to work with wires still covered. https://lh4.googleusercontent.com/-9...313_181854.jpg https://lh6.googleusercontent.com/-L...313_182013.jpg Step 8. Re-install foot well LED and tuck wiring in dash. Re-install plastic trim, take care to align wiring from kick plate as it will be slightly noticeable where it enters the car. For you creative cats I'm sure someone will find a way to run the wire more cleanly; but I wasn't too gung ho about drilling holes into my car here so ran it like so. https://lh4.googleusercontent.com/-l...313_182043.jpg Step 9. Repeat on other side. Step 10. Enjoy. They will do a slight "warm up" then turn on to full brightness when you open the door. https://lh3.googleusercontent.com/-m...313_192955.jpg https://lh4.googleusercontent.com/-f...313_193019.jpg https://sphotos-b.xx.fbcdn.net/hphot...68495524_n.jpg |
Thanks for the writeup, Ghozt! How much should I look to save for this? Definitely going on my list... maybe a sooner mod than later!
EDIT == NVM! Found the price. $125. Not bad at all! |
Very nice write up! I gotta get some of those.
My pleasure ghozt - glad Matt contacted me as soon as these became available because we have been waiting on these for quite some time :)
For those of you that would like to take advantage on the discounted price (as ghozt mentioned) join our FB group: http://www.facebook.com/groups/7thgenmax This was a super easy install and even easier for you 2012+ owners. Both ghozt and I had to do some splicing as mentioned in the DIY. Please visit Matt's online store - he is our official vendor:: www.NissanAccessories247.com and www.MarlboroNissanParts.com Enjoy everyone! :) |
Nice. Great instructions!
Is it possible to change the color? |
Originally Posted by Jig9798
(Post 8750078)
(Post 8750078)
Is it possible to change the color? http://www.the370z.com/exterior-inte...ed-change.html |
Look sick. Added to my mod list for sure
Looks alright I guess.
I like it, it looks great!
Originally Posted by MaximaGuido09c
(Post 8750419)
Awesome DIY as always Ghozt. This needs to be on the sticky.
Not crazy about the black trim around. It would look great without it.
So awesome. I love that. I guess with the LED kit it would blend better than the stock interior lights. I'm definitely doing this. Good Write Up!
Originally Posted by Andre77
(Post 8750767)
Originally Posted by 2themax11
(Post 8750571)
Guido don't be hating brah lol... Haha
My 2013 came with them and my car is Navy blue so it looks pretty cool. I'm looking to install the interior light kit and the exterior security lighting kit on mine someday.
Originally Posted by 2013MAX4DSC
(Post 8751387)
My 2013 came with them and my car is Navy blue so it looks pretty cool. I'm looking to install the interior light kit and the exterior security lighting kit on mine someday. [/FONT][/COLOR]
Out of curiosity how much did they charge you?
(Post 8751409)
If your interested - join our FB group, and reach out to Matt (parts@nissanaccessories247.com) and let him know Dom referred you so at least he can hook you up with the part and then all you would have to worry about is the install. Ground Lighting |
Folks, 2 old timers know better than to sling words and misunderstand..... I cleaned it all up for you both. Don't make me send you both to your rooms without dessert....
Originally Posted by Ghozt
(Post 8750007)
This guide is primarily directed at the 09-11's who will need to splice into the foot wells for lighting. If you have a 2012 these plug directly in and you can download install instructions from most of the Nissan parts websites. I kept the steps easy and materials simple so anyone can do this and reverse it later if they want, however soldering is the preferred method to extend wires. Most of these instructions will also apply to Deadbolt's custom illuminated kick plates that he makes; hit him up if you want custom wording/colors. Tools: Pliers, wire stripper/cutter, butter knife/plastic trim removal tools Materials: 2012+ illuminated kick plates, 4 tap-in connectors (18-24 gauge), 2-4 wire screws, about 4-8 inches of any wire Step 1. Open up the box I hooked them up to a power supply to test; nice looking. Step 2. Remove existing kick panels, I slid my tool under them until I hit a clip then applied upwards pressure Step 3. Pry off trim piece directly next to it. Start by pulling it towards the chair to release inner clips, then pull upwards to pop off Step 4. Cut off the brown plug from the kick plate wiring, trim back the plastic sheath several inches. Step 5. Install new kick plate, it pops right on. Run the wire through the plastic rings towards the front under the dash and have it pop out from underneath Step 6. Extend the wires for the passenger side. You can do this for the driver side as well for more slack but I didn't need to. Here you can use the wire nuts as this guide indicates, or simply solder on roughly 4" extension to both the positive and negative wires. Only strip the wires where you're planning on using the twist wire caps. Step 7. Unscrew bulb from dash, creating slack on the OEM wires to work with. Use the tap-in connectors to splice the red wire from the kick plates to the pink wire of the floor lighting. Squeeze the tap-in connector with your pliers to smash the metal blade and connect the wires. Use the same method to splice the black wire from the kick plates into the yellow wire from the floor lighting. Do not strip wires for this, the tap-in connector is designed to work with wires still covered. Step 8. Re-install foot well LED and tuck wiring in dash. Re-install plastic trim, take care to align wiring from kick plate as it will be slightly noticeable where it enters the car. For you creative cats I'm sure someone will find a way to run the wire more cleanly; but I wasn't too gung ho about drilling holes into my car here so ran it like so. Step 9. Repeat on other side. Step 10. Enjoy. They will do a slight "warm up" then turn on to full brightness when you open the door. |
Originally Posted by Compusmurf
(Post 8751677)
Originally Posted by migonzo02
(Post 8751679)
Loving it GHOSTZ ! Need to get me some of those ! How much do they run for ?
Or you can shop directly from the site and enter coupon code "5555" to receive discount on the site. |
(Post 8751680)
Were you serving New York Cheesecake or a Creme Brulee..or maybe a slice of Pecan Pie? :cool:
Ghozt, those look great, I will have to get me a set. Do they make a set for the rear.
(Post 8752060)
I'm from Florida, you'd have gotten fresh Key Lime Pie!
Originally Posted by t8kover
(Post 8752142)
Cool mod. Looks like it lights up pretty bright!
1 Attachment(s)
(Post 8750007)
This guide is primarily directed at the 09-11's who will need to splice into the foot wells for lighting. If you have a 2012 these plug directly in and you can download install instructions from most of the Nissan parts websites. I kept the steps easy and materials simple so anyone can do this and reverse it later if they want, however soldering is the preferred method to extend wires. Most of these instructions will also apply to Deadbolt's custom illuminated kick plates that he makes; hit him up if you want custom wording/colors. Tools: Pliers, wire stripper/cutter, butter knife/plastic trim removal tools Materials: 2012+ illuminated kick plates, 4 tap-in connectors (18-24 gauge), 2-4 wire screws, about 4-8 inches of any wire Step 1. Open up the box I hooked them up to a power supply to test; nice looking. Step 2. Remove existing kick panels, I slid my tool under them until I hit a clip then applied upwards pressure Step 3. Pry off trim piece directly next to it. Start by pulling it towards the chair to release inner clips, then pull upwards to pop off Step 4. Cut off the brown plug from the kick plate wiring, trim back the plastic sheath several inches. Step 5. Install new kick plate, it pops right on. Run the wire through the plastic rings towards the front under the dash and have it pop out from underneath Step 6. Extend the wires for the passenger side. You can do this for the driver side as well for more slack but I didn't need to. Here you can use the wire nuts as this guide indicates, or simply solder on roughly 4" extension to both the positive and negative wires. Only strip the wires where you're planning on using the twist wire caps. Step 7. Unscrew bulb from dash, creating slack on the OEM wires to work with. Use the tap-in connectors to splice the red wire from the kick plates to the pink wire of the floor lighting. Squeeze the tap-in connector with your pliers to smash the metal blade and connect the wires. Use the same method to splice the black wire from the kick plates into the yellow wire from the floor lighting. Do not strip wires for this, the tap-in connector is designed to work with wires still covered. Step 8. Re-install foot well LED and tuck wiring in dash. Re-install plastic trim, take care to align wiring from kick plate as it will be slightly noticeable where it enters the car. For you creative cats I'm sure someone will find a way to run the wire more cleanly; but I wasn't too gung ho about drilling holes into my car here so ran it like so. Step 9. Repeat on other side. Step 10. Enjoy. They will do a slight "warm up" then turn on to full brightness when you open the door. Attachment 4031 |
Sigh............I need to stop coming here. I've spent a grand in the last month because of this site and it looks like I'll be spending more. :)
Originally Posted by pdub34
(Post 8783572)
Nice Ghozt, I did mine and thanks for the write up. I figured out a way to make it look flush, the kit provides you with felt tape and zip ties, lifting the weather strip up you can place the wiring under it. The wires are protected by a mesh protector and stuff so when the weather strip goes back in place it doesn't damage it and the felt tape keeps it in place. The install guide is on the Nissan 247 accessories site for the item when you view more details about it. Here's a pic of what it looks like!
Attachment 4031 |
Originally Posted by DocHolliday
(Post 8784098)
(Post 8784098)
Lets see what I've bought.
Tint - Installed Fog light kit - Installed 5K HID - Installed Splash Guards - On order Factory Spoiler - On order Ground lights - On order Now it looks like I'll be adding the kick plates. I have a 2012 so it should be a simple install. I'll wait till next paycheck. Also I think I'll be plasti dipping my grille. The video on doing the trim looks like a winner as well. Tempted to try it. |
I have a 2012 Maxima. Have emailed the link above in the first post for a quote on these illuminated kick plates. The only install instructions I see on the Nissan web site are these and nothing specific for the 2012:
http://www.gregcutshaw.com/maxima_il...ting_plate.pdf No mention of an existing connector other than removing the instrument cluster to get to the BCM. These seem to be published in 2010. Anyone have a link to the 2012 specific install instructions? Greg |
Oops. Just found the 2012 install instrucitons:
http://www.gregcutshaw.com/3951_Maxi...structions.pdf Greg |
2012 Maxima, got mine done in just under an hour. The factory instructions were dead on and all the built in connectors were easy to see and access.
http://www.gregcutshaw.com/Maxima%20...ed%20Sills.jpg |
Any chance these newer illuminated kick plates can be installed in a 2000-2003 Nissan Maxima SE? I can't seem to find any DIY on the forum. Any help would be appreciated!
© 2024 MH Sub I, LLC dba Internet Brands
