2011 Max and Homelink program issues
Old Apr 3, 2013 | 01:17 PM
atorreon's Avatar
so i got a 2011 Max and i just replaced the garage door opener in my 3rd garage with a internet capable craftsman. i try to link the Max with it and the thing just wont read the code. My wife tries it in her Infiniti and everything works with no problems at all. I've tried all the basic troubleshooting, clearing the memory, re-seating the fuses, tapping the learn button, etc... anyone else see a problem with this?
Old Apr 3, 2013 | 04:52 PM
majblu2k2's Avatar
So I had this problem with my 2011 Max and 2006 Trailblazer SS. I upgraded my opener to the "MyQ" technology similar to your Craftsman and the problem is linked to the new "security" technology used in the openers. Cars made later in 2011 and 2012 have the newer security protocol and thus work with the newer openers. I had to get a repeater that Liftmaster supplied me for free. I am not sure if Sears is offering the same.
The way it works is you pair the opener to the repeater and then you pair the homelink in the car to a remote supplied with the repeater. The bad part is the repeater needs its own power source and is not supported by the battery back up in the opener. So if your power goes out you won't be able to open the door from your car.
I hope this helps.
Old Apr 4, 2013 | 09:16 AM
LtLeary's Avatar
I had the same issue with my 09 and my brides Jeep. Ended up clearing everything on the Opener and on both cars and then linked my Max FIRST and then the Jeep and voila` both came up.
Good Luck
Old Apr 4, 2013 | 10:21 AM
atorreon's Avatar
I hope this helps.
thanks i'll def look into the repeater
Old Apr 4, 2013 | 10:22 AM
atorreon's Avatar
Good Luck
yea...it sucks i tried doing the same hoping it would fix the issue
Old Apr 10, 2013 | 11:49 AM
joshb00's Avatar
I called homelink (you can find the number on their website) and they are sending me a repeater free of charge. I think if your car isn't relatively new, they will charge you for the repeater. I haven't received it yet, but from what I read online, it should solve the problem. I have a 2012 max and just bought a chamberlain whisperdrive with MyQ and battery backup.
Old May 30, 2013 | 10:52 PM
rader023's Avatar
Did this fix the problem? I have a 2012 and mine always worked, but when I switched to the MyQ opener i have not been able to pair.
Old May 31, 2013 | 04:41 AM
joshb00's Avatar
Yes. It fixed the problem. It just needs to be plugged in within receiving range of the opener. It's not protected under the battery backup, but I figure I can get out of the car and use the keypad if the power is out. Give them a call and they'll send one right out.
Old Jun 2, 2013 | 07:01 PM
rader023's Avatar
Thanks for the tip!
Old Jun 3, 2013 | 10:00 AM
rader023's Avatar
Called homelink and they kept fighting me that is should work, but my mirror never trains so I don't know what they are talking about. After some fighting they are sending me a repeater.
halfpol
Oct 17, 2022 12:16 PM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
Huttig2009
Sep 25, 2015 03:31 PM
rhill4193
Aug 31, 2015 08:18 AM
Gildarts
Aug 31, 2015 07:10 AM
