Clear Vinyl Wrap Help
Old May 6, 2013 | 07:33 AM
T Marsh's Avatar
I just bought some of the clear bra vinyl wrap to put on to my 2012 maxima. I bought it from ijdmtoy.com and was wondering if anyone has any experience with this stuff? Wanted to use it on the front bumper and maybe even wrap the headlights for protection.
Or any tips/ideas on how to put it on the best?
any feedback would help
Old May 6, 2013 | 12:31 PM
TBA's Avatar
TBA
I bought a clear bra kit online, figuring it would be not bad because I'm handy.
Tips:
  • Find clear bra installation videos. Watch them. Repeat. Pay attention to the details. They make it look so easy to get a great result. It isn't.
  • Use lots of the wetting solution. Don't skimp.
  • Get the air bubbles out BEFORE squeegy-ing down the area. Once stuck the film doesn't like getting pulled off.
  • You have to really stretch the material around curves. Probably more than you expect.
  • Try to get it warm so it will stretch easier.
  • Allot more time than you think you'll need.
  • Be prepared to trash a piece or two. Start with the small pieces.
  • Use a high-quality tool.
Lastly, as expensive as it is I'd probably leave installation to a professional next time. There is a pretty steep learning curve. By the time you figure out all the tricks for your particular material, the project is done and the mistakes are on your car.
Old May 6, 2013 | 05:08 PM
T Marsh's Avatar
Tips:
Appreciate the feedback man. The wrap from that website was only like $8 and I bought 3 rolls enough to do what I want and some.
So if anything, didnt spend too much on the film so it's not much of a loss. Ill probably give it a shot tomorrow. Thanks!
Old May 6, 2013 | 05:44 PM
zoemayne's Avatar
I've heard that you shouldnt do the headlights because of the heat headlights can generate. So if the headlights generate too much heat you might now want to put em on there. Prob should start a forum on that topic... I'm not sure how much heat the max's headlights generate prob should of stuck w 3M: http://my350z.com/forum/exterior-and...y-lamin-x.html
Old May 8, 2013 | 12:44 PM
Glenns25's Avatar
Clear Bra
I have an 09 max and had a clear bra put on in my first month. They did the headlights and there has been no problem with heat and my lights look brand new. Would suggest letting a pro do the install though. There are some very tricky areas on the max.
Old May 8, 2013 | 04:48 PM
13Maximasv's Avatar
So are you saying youn have to cut the plastic yourself ? I believe all the clear bras the dealers install are pre cut pieces
Even if you put it on correctly I can't see how you could cut it youself and make it look decent............GOOD LUCK
Below is what you need IMO
http://www.cleardefender.com/2010-ni...r-bra-kit.html
Old May 9, 2013 | 10:28 AM
TBA's Avatar
TBA
Ditto on the cutting out. Mine was a pre-cut kit. I would be nervous as heck trying to make cuts when the film is on the car. I've heard some really skilled guys can do it, but more often the paint gets cut.
Good luck! The front grill is really intricate.
This is what I used. http://www.diamond-shield.com/
Old May 10, 2013 | 09:10 AM
whit's Avatar
My friend and I have the vinyl on headlight for a while. No issues.
Old May 10, 2013 | 10:42 AM
Siizzzoooo's Avatar
THIS is the way to go.
front bumper is the trickiest, even with a precut kit, it took me about 2 hours.
Everything else, hood, fenders, mirrors, top bumper should take about 1-2 hours depending on experience.
Prep is key as well. Clay and wax well. Touch up any areas that need it.
Don't cheap out, this is a VERY good investment to protect your car. I wouldn't half *** it and regret it later on
Apr 16, 2020 05:15 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Redfox
Sep 28, 2015 10:41 AM
