What are people using to adjust rear camber?
Old Jul 15, 2013 | 10:14 PM
MaximaDrvr's Avatar
I have seen camber bolts for rear adjustment, and replacement arms that are adjustable. What are people using, recommending for adjustments?
Old Jul 15, 2013 | 11:05 PM
Boslax6123's Avatar
My install is in two weeks but I'm adding the SPC arms which also come with the toe bolts. I've read a lot about how best to bring the camber back to neutral and this was the best fit. I'm adding a rear sway bar to go along with springs and spacers.
Old Jul 16, 2013 | 12:37 AM
II KRUCKUS II's Avatar
SPC Rear Camber Arms with Toe bolts and Eibach front Camber Bolts. This will get everything into the green with Eibach springs
Old Jul 16, 2013 | 05:13 AM
Ghozt's Avatar
08 350z rear eibach/spc lower control arms
Old Jul 16, 2013 | 10:14 AM
09max_sv's Avatar
A nice DIY (updated) from people who have a perfect "pass" using the mentioned parts above would be handy for people are going to lower their cars.
It will prevent all the questions and speculations, and searching the endless post to find out what works and doesn't..
To the members who commented in the thread, please don't take it the wrong way.
Old Jul 16, 2013 | 12:01 PM
Ghozt's Avatar
I'd get all this stuff installed at a shop, and have it aligned immediately after. When you adjust the camber on the rear with the control arm, you affect the toe (which needs to be adjusted with the toe bolt) which if off can really burn through your tires. unless you have your own alignment equipment to make sure you are adjusting the camber/toe correctly, you'd be wasting your time cause the alignment shop is going to have to at least partially take it back off to adjust it.
Old Jul 16, 2013 | 12:27 PM
rader023's Avatar
If only doing eibachs has anybody been off in the read besides just camber? I am in the green for everything but rear camber and even that is very minor. That is with no new hardware.
Old Jul 16, 2013 | 12:31 PM
Ghozt's Avatar
Some people need alignment after Eibach's, some don't. We also need to take in account that alignments are simply occasionally needed, regardless if you're lowered or not. I personally didn't need it until after I got spacers, even then it was just out of camber.
Old Jul 16, 2013 | 06:28 PM
MaximaDrvr's Avatar
I am only off in rear camber. everything else is green.
Can someone post a link to where the rear camber kit can be purchased?
Old Jul 17, 2013 | 06:56 PM
BLU-IVY's Avatar
Anybody running coils.
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
