Eibach Springs binding problem
Old Jul 21, 2013 | 01:29 AM
mkstimulus's Avatar
I am getting a popping noise when turning my wheels all the way to the left or right, anyone else with eibachs gotten this problem? How did you go about fixing the binding issue.
Old Jul 21, 2013 | 03:50 AM
Ghozt's Avatar
try rotating the spring, that fixed it for a couple other people
Old Jul 21, 2013 | 08:15 AM
Maximam's Avatar
Its likely the spring was not installed aligned with the strut. There is a ledge the end of the spring must land in during install.It possible you can lift the car and try to turn the spring so the end of the spring is aligned with the ledge on the strut housing/spring perch.
Old Jul 21, 2013 | 11:26 AM
dr_2010SV's Avatar
Exactly, this applies to both the top and bottom. The rubber insulators are formed to fit into the "notched" recess just as the coil end of the spring should.
Old Jul 21, 2013 | 08:49 PM
mkstimulus's Avatar
Thanks for the advice, I will check it out when I get the chance.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
Stagnet04
Sep 13, 2015 09:32 PM
pjgreek
Sep 9, 2015 09:30 PM
