some questions about maintenance
Old Nov 26, 2013 | 10:51 AM
sonycrr's Avatar
Hey
new member here
i have my brothers maxima for a little while and noticed that he has not done any maintenance other than oil changes
has 15k miles
2009
i was reading the maintenance book and it says to do the 30k service at 30k or 24months.
this car is 4-5 years old already.
should i get the 30k service done now?
which changes the transmission oil, coolant, differential oil (not sure if the maxima gets this?), replace engine drive belt..
anything else that i should get done to this car at this point?
thanks!
Old Nov 26, 2013 | 11:07 AM
13Maximasv's Avatar
Originally Posted by sonycrr
Hey
new member here
has 15k miles
2009
thanks!
My dad has a 2002 Maxima with a about 15K miles. I change the oil on it once a year for him and had to replace the belts and tires at about the 8 year mark because they were dry rotting
Tranny fluid, coolant, etc has never been touched
Old Nov 26, 2013 | 11:26 AM
sonycrr's Avatar
thanks for the help!
Old Nov 26, 2013 | 12:49 PM
Boslax6123's Avatar
Manual on m '12 called for a brake fluid change at 15k. That has been a change from older version 7th Gens I believe. I got the changed and noticed an immediate difference in the feel of the peddle and bite range.
Old Nov 26, 2013 | 01:27 PM
zoemayne's Avatar
It depends! Just check mainly the Tranny fluid condition to be safe. Better safe than a few grand sorry(its out of warranty by now i think)
Old Nov 26, 2013 | 01:56 PM
sonycrr's Avatar
how to check condition of tranny fluid?
Old Nov 26, 2013 | 02:12 PM
Tommy6905's Avatar
Am I missing something, the op says his 09 doesn't have a cvt...
Old Nov 26, 2013 | 03:04 PM
sonycrr's Avatar
i added that in later
sorry for the confusion..
Old Nov 26, 2013 | 03:10 PM
shook187's Avatar
You never heard of the special edition 6-speed manual?
Old Nov 26, 2013 | 04:12 PM
13Maximasv's Avatar
I thought the 09's had some crazy 10 year CVT warranty ?
My dealers 15K service includes
In Cabin Filter, oil, wiper blades, change brake fluid, tire rotation, replace wiper blades reset tpms inspect CVT fluid and a host of other things for $260
Might not be a bad idea since the car is getting old.
I only say to do this because the in cabin filters can start to smell and Nissan recommends changing brake fluid on these cars every 15K
Old Nov 26, 2013 | 04:14 PM
Tommy6905's Avatar
That car would be the *****
Old Nov 26, 2013 | 06:04 PM
sonycrr's Avatar
so since the car is not cvt..should i change transmission oil?
thanks!
Old Nov 26, 2013 | 06:10 PM
dr_2010SV's Avatar
thanks!
No, I wouldn't change your CVT fluid....yet.
Old Nov 26, 2013 | 06:17 PM
13Maximasv's Avatar
thanks!
Just do a basic 15k service, about $300 bucks
The dealer will most likely try to sell you everything, just say no
Old Nov 26, 2013 | 06:54 PM
trailer54's Avatar
Old Nov 27, 2013 | 05:33 AM
silberma's Avatar
Compared to other cars the Maxima service intervals seem excessive. The engine oil monitors on other cars basically required oil change at 8-10K. Why a much shorter interval on the Maxima. Other high compression engines with turbocharges which are more severely stressed like a BMW 535 require oil change at 1 year interval. What is special on the Maxima engine? Is it just more profit for the car dealer?
Old Nov 27, 2013 | 06:13 AM
Boslax6123's Avatar
Ever since I remember oil changes are done at 3000-3500k, Nissan asks for 3750k change intervals - perfectly normal to me. The premium service asks for many things that can be skipped and done later, however if much rather follow the fluid change intervals for peace of mind.
Change oil once a year, yikes!
Old Nov 27, 2013 | 11:28 AM
13Maximasv's Avatar
BMW's have factory synthetic oil that needs to be changed less often than Dino oil and most BMW owners will tell you the reason the maint is so stretched out is because it's included in the price of the car for 4 years so BMW has less expenses.
The Nissan dealer near me charges $25 for an oil and filter change, any $$ is made on the upsell
Old Nov 27, 2013 | 05:58 PM
lightonthehill's Avatar
thanks!
We have a few posters kidding around here about the CVT/non-CVT thingie with the 2009 Maxima. In case any newbies may be wondering, EVERY 2009 Maxima has a CVT.
Even further, the last Maxima ever built without a CVT tranny was a 2006 model built in July of 2006. All Maximas built since then have a CVT tranny. No other tranny options have been available on any Maxima since the 2006 model year.
The dealer has a CVT fluid checking device that enables a quick check to determine if the CVT fluid needs changing. Although Nissan recommends that the fluid be checked at 30K miles, Nissan also says that, under normal driving conditions, the fluid will be fine until 60K, at which point I would change the fluid, even if the service test says it is still OK.
Those driving regularly on unpaved roads, driving very aggressively or pulling trailers may opt to switch earlier, say at 30K or 45K.
Old Nov 27, 2013 | 11:51 PM
dr_2010SV's Avatar
There should never be any kidding about your cars maintenance.
You should always have an available manual provided at vehicle purchase, used or new.
Please read it and understand it.
Old Nov 28, 2013 | 05:44 AM
sonycrr's Avatar
thanks for the info!
didnt know this.
the only time i went wot was in manual mode..fast car
Old Nov 28, 2013 | 06:14 AM
silberma's Avatar
You are not up to date on engine oils or the Nissan requirements. SAE classifies engine oil with ratings. Originally it was SA oil which lacked many of the properties of current modern SN oil. Current SN oil has improved performance characteristics such as improved high temperature deposit protection for pistons, more stringent sludge and oxidation control and seals compatibility. Therefore practically all auto manufacturers changed the oil change interval to 7,500 miles unless driven in severe conditions.
In fact if you read the Nissan maintenance manual it sates that oil changes are recommended every 7,500 miles or 6 months unless driven in severe conditions where it should be done at 3,750 or 6 month intervals
PS sever conditions requiring oil change at 3,750 miles are:
Repeated short trips of less than 5 miles in normal temperatures or less than 10 miles in freezing temperatures.
Stop-and-go traffic in hot weather or low speed driving for long distances.
Driving in dusty conditions or on rough muddy, or salt-spread roads or Towing a trailer
Old Nov 28, 2013 | 08:07 AM
Boslax6123's Avatar
You are not up to date on engine oils or the Nissan requirements. SAE classifies engine oil with ratings. Originally it was SA oil which lacked many of the properties of current modern SN oil. Current SN oil has improved performance characteristics such as improved high temperature deposit protection for pistons, more stringent sludge and oxidation control and seals compatibility. Therefore practically all auto manufacturers changed the oil change interval to 7,500 miles unless driven in severe conditions. In fact if you read the Nissan maintenance manual it sates that oil changes are recommended every 7,500 miles or 6 months unless driven in severe conditions where it should be done at 3,750 or 6 month intervals PS sever conditions requiring oil change at 3,750 miles are: ● Repeated short trips of less than 5 miles in normal temperatures or less than 10 miles in freezing temperatures. ● Stop-and-go traffic in hot weather or low speed driving for long distances. ● Driving in dusty conditions or on rough muddy, or salt-spread roads or Towing a trailer
Bud, don't get technical on me. In fact read your manual too. I did. It states, change oil at every 3750. I don't think you wrote the manual, nor do you know the type of oil I use or my driving conditions nor have you read my UOA.
Thats only speaking for me though.
I suspect Nissan just made a blanket statement to have EVERYONE do changes at intervals of 3750. Does everyone use the same oil, no. Does everyone drive the same, no. So to be safe it's much better to change your oil at the Nissan Recommended intervals.
I've driven Nissans all my life, owned 5 of em. The only time I changed oil at 7500k was with synthetic Mobil1, never would I do a change using Dino at that high of mileage.
Btw I use Nissan Ester oil and it's nothing special aside from the Ester additives and it still requires a change at 3750.
That is all.
Old Nov 29, 2013 | 05:44 AM
silberma's Avatar
That is all.
Sorry about being technical but lets not dummy down the forum users. I practiced engineering for over 4 decades and can't help myself being technical. In reference to your comments:
1. Read page 15 of your maintenance manual. It clearly states that for normal service (schedule 2 , less severe) oil changes are required for the Titan and Armada at 3,750 miles and all other models at 7,500 miles.
2. Unless you stocked engine oil from years ago, oil available now is SN oil.
If you want to over-maintain your car it is your prerogative. Although oil change shops rip off customers by telling them to come back for oil changes at 3,000 miles, lets not try to convey the message that the normal oil change interval for the Maxima is 3,750 miles.
Old Nov 29, 2013 | 09:29 AM
Boslax6123's Avatar
Sorry about being technical but lets not dummy down the forum users. I practiced engineering for over 4 decades and can't help myself being technical. In reference to your comments: 1. Read page 15 of your maintenance manual. It clearly states that for normal service (schedule 2 , less severe) oil changes are required for the Titan and Armada at 3,750 miles and all other models at 7,500 miles. 2. Unless you stocked engine oil from years ago, oil available now is SN oil. If you want to over-maintain your car it is your prerogative. Although oil change shops rip off customers by telling them to come back for oil changes at 3,000 miles, lets not try to convey the message that the normal oil change interval for the Maxima is 3,750 miles.
The only time Nissan recommends changing oil at 7500 is only on the very first oil change. Change intervals thereafter call for every 3750k.
Maybe we're talking about two different things. But I don't think Im reading my manuals incorrectly.
Anyways, to each his own. I think we're both chasing our tail here...
Old Nov 29, 2013 | 01:11 PM
13Maximasv's Avatar
So basically 1/3 of the country would fall under schedule 1 based just on where they live, salt/sand (dust) on the roads
It's pretty safe to say a car with 15K miles in ~ 5 years is also used for short trips
Old Nov 29, 2013 | 06:46 PM
Maximam's Avatar
Hey
new member here
has 15k miles
2009
thanks!
Personally, I don't do anything but oil changes the first 75k miles or so with any of prior cars over the years. I won't be doing anything to mine at 30k, just my 6k mile oil intervals.
Old Nov 30, 2013 | 11:33 AM
silberma's Avatar
If you read the maintenance manual more carefully you will find that only the Titan and Armada need continuous oil changes at 3750 miles. The Maxima at 7,500 miles intervals for less sever service.
Changing oil more frequently than needed is just a waste of money and lines the pockets of dealers and oil change stations.
Old Nov 30, 2013 | 01:31 PM
Boslax6123's Avatar
Ok ok you win this one bud!
I consider my driving habits to fall under the more severe category, hence my stubbornness to not agree with you and simple oversight in this argument
I agree that changing oil to frequently is a waste of money.
Old Dec 1, 2013 | 05:10 PM
13Maximasv's Avatar
My local Nissan dealer charges $25 for an oil change, without an upsell they at best break even on the deal it's an oil change/Filter, car wash and 70 point ( the upsell) inspection which all told takes 45 minutes I'm sure.
Not to mention Nisan requires cars under warranty to be maintained. As I said , a good portion of this country falls under schedule 1 based simply on where they live.
After the warranty expires do as you wish but to save ~ $125 ( 5 oil changes) and risking having your warranty voided seems quite foolish especially when there is a TSB regarding a bearing issue that I'm sure Nissan would love to void rather that pay the ~$10k cost of a short block and labor
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
