Relay harness question
Looking at my HIDs from trs and I just wanted to make sure I got it right before the install. So on the side opposite the battery the factory harness will not be used correct? And since the relay harness is being used then the connectors on the bulb that would normally go to the harness and the ballast are not used. So there will be three unused plugs correct? And if that is right, should I wrap the ends with electrical tape or is it fine to let them hang?
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
