Smallest Rims that will fit
Old Mar 3, 2014 | 10:09 AM
rottdog300's Avatar
I have an 09 Maxima SV with 19in Factory Rims. My question is how small can i go for an extra set of rims for the winter without having clearance issues. I tried looking for 18 or 19inch steel rims and couldn't find any. So any recommendations would be greatly appreciated.
Thanks.
Old Mar 3, 2014 | 10:13 AM
Amerikaner83's Avatar
pick up a set of the 6th gen 18" rims. I believe those are as small as you can run due to the brake size on the 7th gen.
Old Mar 3, 2014 | 10:22 AM
nsnrider's Avatar
i'm sure you can get 17's on it, but i haven't tried it. Maybe steelies 16's will clear? Go to a tire shop that sells tires and wheels and see if you can find a competent tech who would help you find the best deal. 18's and 19's tires are very expensive, I understand why you want to get a smaller rim.
It would look weird though on a 7th gen since its such a big car but that's a different story.
Old Mar 3, 2014 | 11:53 AM
KGMtech's Avatar
TireRack suggests that a 17" wheel package is good for snows on the 2013 Maxima. I haven't checked other years of 7th generation, but I would think this 17" diameter would be fine for 2009+
Old Mar 3, 2014 | 12:41 PM
BBmaxi's Avatar
17 is good. U will probably get a lighter response on the throttle due to lighter unsprung weight. Just make sure u get the right size aspect ratio on the tires
Old Mar 3, 2014 | 12:45 PM
Ross2893's Avatar
Probably need an alignment too since it will technically be out of spec running anything below 18s
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Pied
Sep 26, 2015 03:29 PM
