Dual Halo Install Question
Old May 6, 2014 | 01:15 PM
maxipad2011's Avatar
Cool Dual Halo Install Question
If you are to install two halos into each headlight I understand that the projector shroud for the low beam is 70mm but what size should I go with in order to notch the hi beam section and fit another halo in this area? Would it be closer to 100mm?
Old May 6, 2014 | 03:19 PM
escblads's Avatar
I believe Ghozt used 70mm for both the low and high beam area. However, it looks like he did retro a projector in the high beam area, so mounting it without a projector or shroud may get a little tricky to look clean. Or you could easily just buy projector shrouds to mount in the high beam area and place the halos on those, that might be easier.
http://forums.maxima.org/7th-generat...ml#post8197119
Old May 6, 2014 | 07:51 PM
Originally Posted by escblads
I believe Ghozt used 70mm for both the low and high beam area. However, it looks like he did retro a projector in the high beam area, so mounting it without a projector or shroud may get a little tricky to look clean. Or you could easily just buy projector shrouds to mount in the high beam area and place the halos on those, that might be easier. http://forums.maxima.org/7th-generat...ml#post8197119
Yes that's exactly what he did. I love the way it looks but I'm shooting to maintain functionality of my hi beams...I'm also looking to notch the bottom as to create a partial halo look on the halo surrounding the hi beam area.
Old May 7, 2014 | 06:16 AM
Ghozt's Avatar
That was my old build, I retrofitted a full projector in my high beam awhile back and have full functionality of the high beam again. Best way to describe how to do that is get a dremel and get creative.
Old May 7, 2014 | 07:53 AM
The dremel part is what I'm looking at doing Dan....I'm actually going to notch the bottom of the high beam area and use 90mm halos there as to create a partial halo effect and use the 70mm on the low beams. Also painting the larger part of my housing crimson black this go-around.
PH98I30
Jan 9, 2025 08:08 AM
Cotozic
Jun 28, 2017 08:01 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
Habibshaib
Aug 6, 2015 01:19 PM
