Brake Pad question.
Old Jul 22, 2014 | 07:44 AM
bazil769's Avatar
Talking Brake Pad question.
Guys i need help to find brake pads online anyone knows a good website where i can buy cheap genuine nissan parts. I drive a 2010 nissan maxima 3.5SV. Also i have the sports package are my brakes different than regular ones?
Old Jul 22, 2014 | 07:58 AM
Tommy6905's Avatar
No your brakes are the same, courtesyparts.com is a good site for Oem nissan parts
Old Jul 22, 2014 | 08:23 AM
bazil769's Avatar
Thank you for the reponse.
Old Jul 22, 2014 | 08:32 AM
Albert's Avatar
The Nissan pads are quiet, but they tend to fade in stop and go traffic.
Old Jul 22, 2014 | 09:16 AM
bazil769's Avatar
These should be the right ones right? anyone know where i can find a write up or video to use as a guide to replace them?
http://www.courtesyparts.com/41000k-...-p-607515.html
Old Jul 22, 2014 | 03:24 PM
torres460's Avatar
http://www.carid.com/2010-nissan-maxima-brake-parts/
Old Jul 25, 2014 | 12:32 PM
bazil769's Avatar
Should i replace the sensor also? Are there any sensors on these pads?
Old Jul 25, 2014 | 06:52 PM
Daaavid's Avatar
Should i replace the sensor also? Is there any sensors on these pads?
You should be okay with just buying the pads. You are also replacing your rotors, too? If not, make sure the rotors have a clean, level surface otherwise you'll have the dreaded vibration when the pads start to break in. If the car detects that the brake fluid is low due to increased pad wear thus requiring more fluid for the piston to compress, the Brake light will come on anyway, so that's about all the sensors you'll need along with a mechanical sensor... your ears since they'll squeak!
Old Jul 27, 2014 | 06:52 PM
bazil769's Avatar
Wow! Thanks for all the help bro. Can anyone help me out with a write up or video to change the pads myself?
Old Jul 27, 2014 | 07:07 PM
Daaavid's Avatar
It is a simple job, and very straightforward but is labor intensive if it is your first major car repair you've done so be sure to set aside a free day in your schedule.
Here is a video from CARandDRIVER. The job is straightforward as I said, I would research more videos on YouTube if you are uncertain but once you have the wheel off, it'll piece together in your head. Be safe and use a jack stand to lift your car, and for extra cushioning in case of a failed jack stand, place your wheel under the area you will be working on.
http://www.youtube.com/watch?v=y6HxORx0g-g
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
