2011 Maxima Dual Moonroof - Shakes when closing
Old Aug 11, 2014 | 10:21 PM
Boomers93SE's Avatar
Hi,
My 2011 maxima has developed a problem when closing the dual moonroof/sunroof. Upon closing the tracks shake / stutter. It closes all the way and seals, opens fine with no problems.
Is this a known problem?
Thanks,
RM
2011 maxima SV (my 10th maxima since 1990)
Old Aug 12, 2014 | 02:39 AM
2011maximapa's Avatar
Sounds to me like a little grease is needed on the moving parts. Probably just hanging up and shuttering during its cycle.
Old Aug 12, 2014 | 03:32 AM
Tommy6905's Avatar
I have a 2010 and mine does something alittle different that just started, when it's completely closed it'll make three clicking like sounds after, weird
Someone else check there's and let me know if that's normal
Old Aug 12, 2014 | 06:37 AM
VIP_MAXIMA's Avatar
Mine the same thing. It "skips" across the "rails"
Old Aug 12, 2014 | 07:45 AM
dr_2010SV's Avatar
Originally Posted by Boomers93SE
Hi,
Thanks,
RM
This is/has been experienced by numerous forum members. My garage door closes in the same fashion from time to time, it's like it's racking.
Even though I know I shouldn't have to, like the steering wheel exit/entry function I limit my use of these features due to the known issues surrounding them.
Old Aug 12, 2014 | 08:18 AM
Grego214's Avatar
Go to the dealer, they will fix it for free.
Old Aug 14, 2014 | 09:38 AM
Propa Teknique's Avatar
Can this be fixed by adding a certain grease to this? If we can do this at home this would be great. I don't want to go to the dealer, they take forever to do things.
Old Aug 16, 2014 | 07:01 PM
Maxgig's Avatar
When my sunroof started doing this I first tried WD40 (don't do it) it attracted a lot of dust, and I currently live in the desert . After I cleaned it off I next used white lithium grease which works a lot better. My roof opens and closes smoothly now.
Old Aug 16, 2014 | 07:14 PM
1996blackmax's Avatar
Mine started doing this as well. Not always, but it's annoying. Thanks for the tip! I will give that a shot.
Old Aug 17, 2014 | 08:04 PM
lightonthehill's Avatar
My '09 double-panel roof opens and closes very smoothly. If this roof is not opening and closing smoothly, then either something has gotten out of alignment or something has broken or something needs lubricating.
Old Aug 18, 2014 | 06:23 AM
Thanks for the tip. Where exactly do you apply the grease to stop the noise and how much do you apply?
Old Aug 18, 2014 | 07:03 AM
sonomamax's Avatar
grease it
use white lithium grease (can get a tube at autozone,Orelllys,pep boys) and a small paint brush( I use one with the metal tube handle about 1/2 inch wide, I call them acid brush) and open the roof and very LIGHTLY paint on a coat of grease where ever any pieces slide togeather, DO NOT put it on heavy cause of getting it all over.
halfpol
Oct 17, 2022 12:16 PM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
wingsfan24
Aug 15, 2015 07:35 PM
halfpol
Aug 5, 2015 08:24 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
