Can someone please verify tire/wheel size?
Old Sep 21, 2014 | 08:28 PM
Maximam's Avatar
I am looking to install 20x10 wheels with a 40mm offset. I want to run 255/35/20 on all four corners, will this clear up front?
Car will be on Eibachs.
Thanks!
Old Sep 21, 2014 | 09:09 PM
D.Stillwell's Avatar
Thanks!
Yes that should fit fine, some people are running those sizes around here.
Not sure if lowered or stock height tho, I'd be worried bout the 10" width. All the Maximas I've seen with the setup you want run 9 wide at most.
Old Sep 22, 2014 | 06:38 AM
Maximam's Avatar
Ya I like the square setup for the Maxima. Can anyone else chime in, 20x10 with 255/35 up front clear?
Old Sep 22, 2014 | 09:19 AM
MaximaDrvr's Avatar
The tire size is fine.
I run a 9 et30 lowered on eibachs and it is flush with the fender.
10 et40 will stick out 2mm, or nearly no difference. You will at about the factory location on the inside.
You will probably rub on big bumps, but nothing serious.
Old Sep 22, 2014 | 10:34 PM
honest_abe's Avatar
any rub hitting big bumps running the 255/35/20 on your 20x9 et30? how about poke?
i just bought a set of 255/35/20's to wrap around a set of rohana rc22's 20x9 et35 and I'm worried about poke and rub (that sounds funny)
-abe
Old Sep 23, 2014 | 09:14 AM
MaximaDrvr's Avatar
I think the 35 would be fine.
I do have rub on large bumps or road swells.
I'm roughly 2mm inset from flush. It rubs on the fender to bumper attachment tab, and a little on the rear of the fender liner from full lock, full compression bumps.
It is really minimal amounts of rubbing, but u hear it daily.
If I were to order them again, I would have picked a et35.
I am also running a 255/35/20.
Old Sep 23, 2014 | 02:52 PM
Maximam's Avatar
From what I can tell I will have some rub with 20x10 40MM in the front?? Can anyone else chime in?
Old Sep 24, 2014 | 07:37 PM
MaximaDrvr's Avatar
It depends on your tire choice and suspension.
Old Sep 25, 2014 | 06:46 AM
Maximam's Avatar
The post included tire choice and suspension.
Miket2006
Mar 1, 2021 03:55 AM
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
