morimoto X Drl 5 connection
Old Dec 29, 2014 | 06:54 PM
DMAXIM's Avatar
Hello i just bought the morimoto x drl5, and I've heard that they're very bright, so i found this module
http://www.exledusa.com/exled-drl-dimmer-module.html
to control the brightness, it says on the description to tap the white wire to an acc... Now to those who have connected drls to acc, which acc did you guys used?
Old Jan 2, 2015 | 05:28 PM
DMAXIM's Avatar
Anybody??
Old Jan 2, 2015 | 05:32 PM
Wipers would be a good choice. Or anything else that comes on when the key is turned.
Old Jan 2, 2015 | 07:44 PM
escblads's Avatar
Wouldn't you want the full brightness of the DRL while the headlights are off and dim them when the headlights turn on? If so you could just use one of the wires from a headlight harness or at the headlight fuse to dim them when you turn on the lights.
Old Jan 4, 2015 | 08:22 AM
DMAXIM's Avatar
Yes, do you know by any chance where could i find the wipers fuse in thr box?
Old Jan 4, 2015 | 08:23 AM
DMAXIM's Avatar
Yes but for that i would need a module, which the exled ones requires one of the cables to be connected to an acc fuse...
AaronL
Nov 15, 2020 11:52 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
zmcneely13
Sep 26, 2015 02:26 PM
