Fuses
The fuse is not blowing just because you put in a switchback led. It's hard to say exactly why the fuse is blowing, maybe you didn't get the correct model led. I would take the led out and put the original bulbs back in and see if the fuse still blows. Then try putting in the led lamps one at a time and see what happens.
You will need the load resistors for the turn signals to blink properly. But not having the resistors will not cause the fuse to blow.
