2009 Maxima Vibration
Anyone had issues with this? Vibration comes and goes. Feel like tires or drivetrain. Sometimes vibrates at all speeds, sometimes not at all. Have new tires, balanced twice, new rotors. Just purchased car, but would like some thoughts on what to check next.
Vibration happens at all speeds, most noticeable during acceleration. Bought car recently and had brand new Firestone tires. Car is fine for days, and suddenly vibration starts. Vibration not real bad, just enough to be annoying. Have had at 2 dealerships and they could not replicate the problem. Have had tires balanced twice, and replaced 2 wheels with slight damage. Today had vibration at all speeds, took car to 110 MPH, and vibration stopped. Vibration no longer at any speed. I know it will come back, maybe not tomorrow, but the next day for sure. Put on new brake rotors and had car aligned. Still the same issue.
When it is happening (sometimes not at all) you can feel it in the seat, the throttle pedal and the steering wheel. If it happened all the time, it would be easier to diagnose. But is comes and goes, sometimes for days at a time.
I do live in an area that can have ice and snow, but we have not had any this year. Car is kept in a heated garage, so if that does happen, it melts over night. Thanks for the suggestion.
I had an issue and despite being balanced a second time, i got them balanced a third time at a different shop. Mechanic even had machine calibrated between first and second balancing, but i was certain it was still off and the final time i had them balanced, technician said they were definitely off.
I've got another stupid question myself, were they balanced twice at the same shop?
Good point: It was the same shop. I will try a different place to have them balanced. I don't know any place locally that does road force balancing, but would like to try that next.
http://www.gsp9700.com/search/findgsp9700.cfm
I would like to know as well. I just switched back to my stock rims and had an alignment and I have been having similar issues since. I have been back to the same shop twice, had the alignment checked and the wheel balance checked, everything looked good apparently. I might take it to another shop for a second opinion, but I would like to know if and how you got this fixed.
Had the exact same problem with my wife's Maxima. Bought new tires and the problem kept happening. Had it aligned, still happened. Spent $70 and a couple hours replacing the front hub and it's like a new car!
Click on the link. Its a pretty easy fix.
Having similar issues with a 2010 I just purchased. I thought an alignment and wheel balance would solve the issue, but after getting an alignment and wheel balance this weekend, the shaking is actually WORSE- starting at about 40 mph....
dank4us
34
Jun 10, 2024 03:45 AM
09maxshawn11
Aug 14, 2015 10:07 PM
laparka66
Aug 6, 2015 09:36 AM
