Replacing rear sway bushings
The poly bushings that come with the rl sway bar are driving me nuts, I want to put the Oem bushings back on. Are jackstands or a lift required? I'm not a mechanic but Its my understanding the sway bar is not load bearing? Can Ramps be used, I have access to Ramps but not stands....any input is appreciated in doing this myself
Ramps will work. I installed my RL sway bar using only ramps. I'm interested in if the OEM bushings will fit ok since the sway bar is slightly thicker. Once the weather warms up I'm going to either swap out the poly for the rubber OEMS or try wrapping the bar with teflon.
I don't believe rubber bushing need grease. As a matter of fact, some types of grease will degrade the rubber over time. When I took off the OEM sway bar and bushings, I did not see any grease. As for the Teflon, I was going to use that for the poly bushings to try to eliminate the squeaks.
http://www.energysuspensionparts.com...shing-Lube.asp
Been researching this myself since I have a RSB on order. This seems to be a really good lube to use. Not sure teflon tape is overkill or not-- I just heard that you need to really lube the heck out of the bushing before install. I may add teflon tape just for extra measure...
When I installed my rl rear sway bar I used the bushings and grease they provided. After about 2 months I was under the car regreasing the bushings due to a obnoxious squeak/creaking over bumps. A few months later the same annoying squeak/creaking appeared, by then I had enough. Swapped the racingline bushings with the oem ones from the original sway bar, used some Mobil 1 synthetic grease and haven't had a problem in almost a year.
Absolutely. There's a groove in the bracket that goes over the bushings, the oem bushings fill that groove the racingline bushings don't. I'm not sure if that played a role in drying out the grease but I'd like to think so. Either way my older bro has a 7th gen maxima when we did his RL rear sway bar we threw the racingline bushings to the side after the bad experience I had and we stuck with the oem and sure enough he never experienced any squeaking or creaking noises. My advice, stick with the oem bushings and save yourself the trouble.
My sway bar is currently connected to the outer holes with the RL endlinks. On highway turns the car handles better but there is a slight delay before the sway bar kicks in. When time permits I will reinstall to the inner holes. Just curious how you guys have installed it.
Hey guys!
Question for you who have installed the Racingline RSB on a 7th Generation Maxima...
Is the RSB a direct bolt on for the Maxima even if you use the stock end links?
I was reading on an Altima site where the poster said that he had to drill out the holes on the Racingline RSB in order for them to fit on the stock end links. Yeah it was an old post but it got me thinking.
Kind of second-guessing myself now wondering if I should have ordered the Racingline end links as well...
Thanks in advance for any input...
Hey guys! Question for you who have installed the Racingline RSB on a 7th Generation Maxima... Is the RSB a direct bolt on for the Maxima even if you use the stock end links? I was reading on an Altima site where the poster said that he had to drill out the holes on the Racingline RSB in order for them to fit on the stock end links. Yeah it was an old post but it got me thinking. Kind of second-guessing myself now wondering if I should have ordered the Racingline end links as well... Thanks in advance for any input...
As for the end links, I grabbed the top end links because my car is lowered on Eibach springs, and in retrospect it may have not been necessary for me to have done that but just did it for the peace of mind factor. Done and done, ya know?
Are you referring to drilling & elongating hole in sub-frame for proper fitment of SPC rear camber kit & toe bolt? I did that when lowering on the Eibach springs to ensure the car came out all green on the alignment sheet and fell within spec. No issues or any of that and I've kept tabs on it.
Huttig2009
Sep 25, 2015 03:31 PM
MaxStock
Aug 14, 2015 10:03 PM
