RSB Info Needed
RSB Info Needed
HI All, I have been trying to get some info on ordering a RSB from RL. To date I have not received a reply from RL. Does anyone know the difference in diameter of the stock RSB to the RL RSB? Everyone talks about how much better the car handles with the RL bar, but no one mentions the specs on the bars.
Also, is it true that when changing out the RSB and/or Springs, that you should change your endlinks because the stock setup might not be able to handle the stress?
I don't know the specs on the RSB but i have it and I can vouch that you will feel it.
If you are going to use the "track" setting on the RSM, you might want to use order the RL end links as well since this setting might be too aggressive for the OEM end links.
Just swapped out to the RL RSB and kept the OEM end links and used the "street" setting on the bar. Just bought the car brand new last October so I knew the end links were in great shape. If my car had some mileage on it, I probably would have replaced the end links as well just to be safe...
I am not lowered, but when I installed the RL RSB i switched the endlinks to the MOOG links. The MOOG links are factory replacements, but they are much beefier than the OEM links. I think they were ~$20 each.
The only time the RL endlinks would give you any benefit is if you race and want to preload it one way or the other for better cornering. For just street driving, it wont make a difference.
If your car is lowered and you are on stiffer springs, the forces in the endlinks will be less. The force is developed in the endlinks as the car "rolls". If you are lower and the springs are stiffer, the car rolls less, therefore reducing the force in the endlinks and the torsion on the RSB.
Quickgtp
Aug 27, 2015 02:13 PM
TonyJr
Aug 20, 2015 12:14 AM
