Another Offset Question....
Okay fellow members I hope I'm in the right forum but I have another offset question. My brother-in-law is looking to buy a set of rims at a great price. The specs are:
20x9 +25 (245/35/20)
20x10.5 +25 (285/30/20)
will this work on a 2014 Max which will be lowered on Megan Racing Coil overs? Any help would be greatly appreciated. Moderators please move to correct forum. Thank you
Really low on coils it could work, but with a narrower rear tire. Not going to work on eibachs.
I would recommend a different set myself, and I'm on coils. Those aren't worth the probable headaches with the rear.
My wheels have the same specs. The fronts are fine, but the rear will have a poke. 285/30-20 will be to wide, i'm running a 275/30-20 right now in the rear not lowered with rear fenders rolled slightly. I rub a little going over big bumps with people in the rear. I'm planing on going down to a 265/35-20 or a 255/35-20 like suggested by another Max owner befor I lower my car.
Poke.....
How much of a poke from the fender are you? Thanks....
Couple quick shots so people understand poke as it relates to offset and a mild drop since I haven't posted here before. I have no poke relative to these specs and where my setup is to the fender so someone desiring poke can figure out how much further out they would need to go beyond this to achieve the look they want.
If you are going with the akebono setup then you need to do your homework since spoke design, offset and wheel width all work together to determine whether or not you can clear those front brakes. In my case, I wanted no spacers at all and no poke but i did want to get close enough to the fender so it looks nice "to me" without having any issues, spacers or fender modifications.
SPECS:
Savini wheels
20*8.5 Front ET32 on 245/35 and
20*10 Rear on 285/30 ET40
Ebach drop
no fender mods
no rub at all
SPECS:
Savini wheels
Ebach drop
no fender mods
no rub at all
no poke at all. Just trying to help set the context for other folks on what these specs look like. I have no clue why these pics don't show here. When you open in new tab, they pop right up since they are flickr hosted. Thanks for that brake thread by the way. Saved me alot of time.
SPECS:
Savini wheels
Ebach drop
no fender mods
no rub at all
SPECS:
Savini wheels
Ebach drop
no fender mods
no rub at all
20*9 Front ET35 on 255/35
20*10 Rear ET45 on 285/30
I'd also like to not use spacers anymore, but get it lined up nicely with the fender without having any clearance issues or need to roll the fender.
OP , I do have Akebono front and rears on my setup. Don't assume it's all good because you see a wheel width and offset on another wheel which clears those brakes. Spoke design can get tricky and mess you up like MAximaDrvr said. Get the akebono front/rear template and put it on a cardboard to do a test fit on an actual wheel if possible. I did this myself, but I also talked to someone who put my same rims on the G37 sports sedan which have similar offset range as the max and the akebono package standard.
FWIW if you have to do this blindly, you can correlate offset from wheels that show they fit on the element wheels website. They have a very large fitment database and you can pick offsets etc. Use the G37S sedan to do this. Then cross check that information against the specs you want for tire size/offset/ wheel width vs the look you see from many folks here with similar specs. Thats the easiest way to do this blindly with no test fit.
steveyphat
Sep 15, 2015 03:43 PM
[/URL]
[/URL]
