Customize lights inside/Out of vehicle.
I'm thinking about a idea for a light set up for the inside ando outside. I have a 2014 pearl white Max.
1) An artic blue Halo head light set up. 2) Swap out stock lights that come on when you open the doors. Overheard and by feet for artic blue. 3) The stock orange lights that come on behind your radio,navigation and in the general dash board area. My idea is to make an artic blue/icy light theme. Has anyone done this before and how hard would it be to do? I might have to take it to a professional because I'm not good with cars myself and I want it to look good. Any feed back is appreciated. . |
Ummmm I'd say there's a wealth of information regarding lighting on this forum. I'd suggest using the search box.
Many have halos around their headlights (myself included) which is a common and relatively easy mod but involves baking open the headlight assembly and wiring things up to work properly so I'd suggest having a shop do it. The interior door lights are super simple and can be done in a few minutes. The orange dash and radio backlighting is a different story. A few have done it but it requires removing each individual led then resoldering the new ones in place for the entire dash which seems like a pain to me. Anyway, good luck! |
3 Attachment(s)
The amber lighting for your radio, navigation, and dashboard area is a very difficult, and costly job. If you do not have any experience soldering, consider giving it to a professional. Even then, they will charge you about $1,000 for it to be done. The LEDs (PLCC-4) are the size of Lincoln's forehead on the penny.
http://www.oznium.com/images/plcc2_tc_dash_size.jpg Here is what I have done. There is an overhead light next to your sunroof/moonroof controls that lights up the center console and cupholders, and you can change out with a different color LED. The factory color is orange, but I changed it to a 3mm blue LED to contrast the orange on the radio. Attachment 60135 There are also little lights on the under the front driver and passenger door handles illuminating the door lock and window controls. Again, factory color is orange. You can change it to any color 3mm LED. Attachment 60136 What it looks like when it is all said and done. Really helps contrast the orange on the radio, and looks much more modern and luxurious. Attachment 60137 There are vendors out there that sell a plug-and-play projector light for the doors shining a Nissan logo already wired into where the factory 194 incandescent bulb would go. This way, you do not have to drill a hole into your door and do any wiring. For your headlights, you can do it yourself or have a professional do it. There are ton of write-ups on how to bake your headlight open and reseal them, including the current Maxima we have. Many have halos on their Maximas. You will have better quality lights combined with a legitimate warranty through TheRetrofitSource. |
Originally Posted by Daaavid
(Post 9045437)
http://www.oznium.com/images/plcc2_tc_dash_size.jpg Here is what I have done. There is an overhead light next to your sunroof/moonroof controls that lights up the center console and cupholders, and you can change out with a different color LED. The factory color is orange, but I changed it to a 3mm blue LED to contrast the orange on the radio. https://i.imgur.com/qny5kht.png There are also little lights on the under the front driver and passenger door handles illuminating the door lock and window controls. Again, factory color is orange. You can change it to any color 3mm LED. https://i.imgur.com/FnsbaVH.png What it looks like when it is all said and done. Really helps contrast the orange on the radio, and looks much more modern and luxurious. https://i.imgur.com/wjRNONV.png There are vendors out there that sell a plug-and-play projector light for the doors shining a Nissan logo already wired into where the factory 194 incandescent bulb would go. This way, you do not have to drill a hole into your door and do any wiring. For your headlights, you can do it yourself or have a professional do it. There are ton of write-ups on how to bake your headlight open and reseal them, including the current Maxima we have. Many have halos on their Maximas. You will have better quality lights combined with a legitimate warranty through TheRetrofitSource. I'll take another look at these things once I get done work. |
Nicely done Daaavid!
Could anyone recommend a good shop either in NY, around Queens or possibly around Newark, Delaware?
I would like to talk to someone about some halo lights and interior lights. |
Originally Posted by Pboned
(Post 9045629)
How did you manage to change the ambient lighting LEDs. Always wondered about those. Any links or write-ups by any chance?
Just remember, most states have laws against visible blue and/or red lights visible from the vehicle.
1 Attachment(s)
Originally Posted by slatemaxima
(Post 9045830)
Nice walk through.
Thanks. Well done.
Dependent upon what year, model, and package you have, the door light is another story and much more complex. To see if you have a light back there, turn on your parking light or low beams and place your hand behind the handle. All Maximas will have a hole for the light, but few will have a physical light. This is important because if there is actually a light behind there, then your vehicle is wired from the factory. If not, then you will need to run it.
You can pry open the door handle by putting a flathead screw driver or using those plastic trim removal tools on the bottom of the door handle and prying outward. It's held in by clips. To change the door handle light, you will actually need to cut the wire to remove the LED as the housing cannot be removed.
Hmm.. I haven't seen any lights around the door handle area.
need help...
trying to find some good led DTRL / turn signals ive tried a couple sets of bulbs with the resistors but cant seem to figure out why they don't blink, ive got them to turn on with the signal but they just stay on, then if I use the running lights they blow the fuse.... I tired looking for a thread on this but cant seem to find one... any help would do..
Thank you |
(Post 9046133)
Originally Posted by Emoney66
(Post 9046137)
Thank you |
(Post 9046139)
I will see if I can find a write up on how to wire it easily if you don't have the package.
[QUOTEYou need 3157CK base bulbs. If it is just a regular 3157, you will blow fuses.[/QUOTE]
Thank you :) |
(Post 9046139)
Wires?
(Post 9046124)
© 2024 MH Sub I, LLC dba Internet Brands
