350z Brembo Brakes
Old May 13, 2015 | 08:19 PM
sdc711's Avatar
350z Brembo Brakes
Looking to see if anyone might know if a 14" rotors 4caliper piston brembo GT**brakes would fit my 2010 maxima?
Here's the link
https://conceptzperformance.com/Cart/description.php?II=9021
Old May 13, 2015 | 09:19 PM
MaximaDrvr's Avatar
The 14" Akebono kit from the 370 is a direct bolt on.
Search for threads I've made to find my write up on that kit.
Old May 14, 2015 | 06:02 AM
Tbone3944's Avatar
"The 14" Akebono kit from the 370 is a direct bolt on.
Search for threads I've made to find my write up on that kit."
MaximaDrvr do you know if that kit is a direct bolt on for the 2010 Maxima as well? I saw your thread and I think you had a 2014 if I'm not mistaken. Thanks!
Old May 14, 2015 | 12:03 PM
RCM78's Avatar
Same car...
Old May 14, 2015 | 12:53 PM
Tbone3944's Avatar
I figured that but thought I'd ask and be safe before spending roughly $2k on brakes. They are always changing things here and there each year that's all. Thanks.
Old May 14, 2015 | 04:11 PM
Asav's Avatar
I just did this on a 2011 using MaximaDrvr's write up. Worked like a charm with no headaches at all. Very straight forward provided you understand brakes in general and truthfully even if you don't you can follow it. Pull the trigger!
Old May 14, 2015 | 05:35 PM
MaximaDrvr's Avatar
Yep, they bolt on to all 7th gens with no problems.
Old May 19, 2015 | 07:18 PM
sdc711's Avatar
Thanks MaximadDrvr i decided to bite the bullet and order the Akebono kit also. Can't wait to see what they'll look like installed plus getting my headlights in from Ghozt around the same time
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
