Drm vs drs spacers
Old May 16, 2015 | 05:18 PM
fame126's Avatar
Drm vs drs spacers
Im Leaning towards drm spacers because I want my rims n tires bolted directly to hub vs Drs which is bolted to spacer then to Hub. Is there any reason why one is better than the other? Which do you have? Thanks
Old May 16, 2015 | 11:50 PM
1996blackmax's Avatar
I've had the DRM for two years now. I didn't feel like dealing with the longer studs & went with ease of use. The DRM spacers bolt up to your car then the rim gets bolted onto the spacer.
Old May 17, 2015 | 08:51 AM
fame126's Avatar
I've read to have them hand torqued. Is this correct? If so, is there as specific pound to torque the lug nuts to?
Old May 17, 2015 | 09:36 AM
I believe it was 85 foot lbs. Same as Nissan recommends for the rims. When I first put them on, I took my rims off & checked all the spacers again. I also do this any time the spacers need to come off (ie. getting breaks done).
Old Jun 4, 2015 | 10:02 PM
rEVIL's Avatar
How fits drm spacers f25mm and r30mm on 19s with eibach pro springs?
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
