Newbie Sway Bar Question
Old Sep 23, 2015 | 07:13 AM
gman214's Avatar
I just got a '12 Maxima S and see there're sway bars available. What is the advantage(s) of installing sway bar(s)? I have a feeling I know after driving for a week. But want others' inputs.
Old Sep 23, 2015 | 08:13 AM
DennisMik's Avatar
A sway bar's purpose is to reduce the amount the car leans to the side when you are going around a curve or corner. It also helps on straight roads as roads are not level and the car can also pitch from side to side.
The sway bar is a spring, so if you get a stiffer one, the car will not lean as much, but the ride can become a little stiffer/harsher as well, because the sway bar also helps to smooth out pot holes.
Old Sep 23, 2015 | 08:48 AM
dmcmahan12's Avatar
It will also help your car not float like a boat at highway speeds. Best bang for your buck upgrade if you ask me. Stillen rear sway bar and was and still am pleased with the ride quality!
Old Sep 23, 2015 | 09:00 AM
MaximaDrvr's Avatar
RacingLine has two adjustment points. Soft is 50% stiffer, and firm is 100% stiffer than factory.
It is easily the best handling mod, especially for the money.
Old Sep 24, 2015 | 05:57 AM
catalinvint's Avatar
Will it have any improvement on my Sport model ?
Since the SV Sport is supposed to have a better sway bar.
That is a question for the guys with SV Sport who have this mod done.
Old Sep 24, 2015 | 06:23 AM
Ross2893's Avatar
Better sway bar in the front. Same day bar as the other maximas in the rear
Old Sep 24, 2015 | 06:40 PM
ThinBlue82's Avatar
You will see a vast improvement.
Old Sep 25, 2015 | 03:03 PM
Bificus99's Avatar
I love sway bar mods, not too terrible install and easy to return to stock. I'd like to do both front and rear on my SV with Tech package non sport. Id love to pick up a sport front bar for oem goodness and an aftermarket rear bar.
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
Stagnet04
Sep 14, 2015 11:28 PM
