Need Help Rim Width/Offset Question
Old Oct 15, 2015 | 07:28 AM
09Blaxima's Avatar
Im looking at purchasing a set of 20x8.5 wheels with a 20mm offset. My concern is these will not be flush with the fender and stick out. Any help with this will be awesome.
Old Oct 15, 2015 | 09:29 AM
MaximaDrvr's Avatar
It depends on if you are lowered, and how much.
I run 20x9 et30, on coils, and they are inset. They were flush on eibachs.
A 8.5 et20 will only be 4mm farther out than mine.
Slight poke at stock height, near flush on springs, slight tuck or more on coils.
Old Oct 15, 2015 | 10:06 AM
09Blaxima's Avatar
Its stock right now, going to get the eibach pro kit in the future for a small drop but wont be going to low.
Thanks for the Info MaximaDrvr....not sure im down for a poke look though
Old Oct 15, 2015 | 12:19 PM
lexcitement's Avatar
4mm, is not much lol
Old Oct 15, 2015 | 03:47 PM
MaximaDrvr's Avatar
I think it would be fine with a 245/35/20
Old Oct 22, 2015 | 10:37 AM
09Blaxima's Avatar
Ended up buying the 20x8.5 set. Company i bought them from offered to adjust the offset for me free of charge for a better fit. They took it from +20 to +25. Im hoping this will be close to perfect at stock height. Concern now is how goofy will it look until i can get the eibachs on it lol? Anyone running 20s with stock ride height that has pics?
Old Oct 23, 2015 | 08:28 AM
Maximam's Avatar
Adjust the offset? That is either done by adding a spacer which would push it out and in your case they would remove material from the rim which I am not a fan of.
In your case, how did they "adjust" the offset?
Old Oct 23, 2015 | 10:17 AM
REDinLV's Avatar
^^^Curious as well. By the sounds of it, they're going to mill it down. Interested in how this turns out.
Old Oct 26, 2015 | 01:29 PM
aireckone's Avatar
didnt want to start another thread but ill jump in this one
20x10.5 +36 square setup work?
Old Oct 26, 2015 | 05:01 PM
MaximaDrvr's Avatar
Not at stock height or on springs.
Coils maybe with stretched tires
Old Nov 10, 2015 | 03:11 PM
andreevans903's Avatar
I have a 22X11 +45 offset on rear and a 22X9 +35 offset onmy max no modification needed
Old Nov 26, 2015 | 03:27 PM
Asav's Avatar
Half the cheap wheels ($500< per rim) people buy ship as blanks and get milled later to fit offset and bolt pattern. This is no issue if done correctly.
02whitemaximase
Nov 28, 2018 07:42 AM
lexcitement
Wheels/Tires
Aug 27, 2016 01:23 PM
Stagnet04
Oct 11, 2015 08:16 PM
yamez57
Oct 10, 2015 06:46 PM
Frank Fontaine
Oct 5, 2015 09:49 AM
