Slightly bent wheel
Old Nov 24, 2015 | 04:53 PM
Zygi's Avatar
Slightly bent wheel
Around a year ago I hit a large pothole (Thank you NYC DOT for fixing the roads in a timely fashion........a$$holes) resulting in a slight dent, almost unnoticeable. I'm wondering if I should repair it or just keep driving? if it is indeed fixable, can someone recommend a reputable wheel repair shop in NYC?
Thanks.
Old Nov 24, 2015 | 06:21 PM
MaximaDrvr's Avatar
If it balances out, don't worry about it. If is really slight, you will never notice.
If it bugs you, it should be under $150 to get it fixed.
Old Nov 25, 2015 | 08:49 AM
240tomax's Avatar
Have a tire shop take the tire off and see if the wheel bead is damaged. I doubt it is damaged or it would leak air.
Old Nov 25, 2015 | 09:13 AM
MaximaDrvr's Avatar
^that would be a waste of money.
Old Nov 25, 2015 | 11:48 AM
240tomax's Avatar
Piece of mind is worth something
Old Nov 25, 2015 | 12:09 PM
r68a5200's Avatar
You should have a shop check the runout on the wheel. Limit is 0.3 mm / 0.012 inches per the service manual.
Old Nov 25, 2015 | 01:25 PM
Richard66's Avatar
If you hit the pot hole to cause a dent in the wheel, then you could have suspension, steering, tire and alignment problems. A lot of these things are unseen by the untrained eye. I would get it checked out. As someone suggested peace of mind is worth something.
Old Nov 25, 2015 | 03:05 PM
MaximaDrvr's Avatar
It happened a year ago per the OP.
If there aren't tire wear problems, then it isn't hurting anything.
I spent 5 years as a mechanic, and wheel and tire and suspension is my thing.
CS_AR
Nov 25, 2015 06:01 AM
Vistance
Nov 22, 2015 11:03 PM
Wjanifer1
Nov 22, 2015 08:49 AM
Will
Nov 21, 2015 11:57 AM
