Will 245-50-18R fit?
Old Dec 25, 2015 | 08:36 AM
Jpags's Avatar
I have an opportunity to pick a set of 245-50-18R blizzaks mounted on 18x8" Sport Edition rims. Will these tires fit on my 2014 Maxima SV Sport? Will I having any rubbings issues?
Old Dec 25, 2015 | 02:50 PM
MaximaDrvr's Avatar
They will fit and won't rub. Your speedo will be off a bit.
Old Dec 25, 2015 | 05:09 PM
vball_max's Avatar
Yes, assuming you are stock height. But also make sure the bolt pattern and bore diameter of the rims is correct.
Old Dec 27, 2015 | 11:55 AM
Jpags's Avatar
The bolt pattern is 5x114 and the offset is 35mm. They were used on a 2011 InfinityM37. Do you think they will fit with a 35mm offset?
Thanks for you help
Old Dec 27, 2015 | 11:58 AM
MaximaDrvr's Avatar
Yes, they will fit fine.
Kriis Bittola
Oct 27, 2015 04:50 PM
lightsandsirens
Oct 25, 2015 08:11 AM
Heat0212
19
Oct 20, 2015 07:25 AM
JakeOfAllTrades
Oct 14, 2015 07:30 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
