CV Axle Swap
Old Apr 29, 2016 | 03:33 PM
r1dustin's Avatar
CV Axle Swap
Hi All,
I've been lurking here for a while, just registered to post a question I couldn't find the answer to.
I'm swapping the axles on my 09 Altima, along with some other work. When I pulled the drivers side axle, a bunch of fluid, which I'm guessing is the super precious CVT ATF, drained. Is that ATF? Or is it something else? Do I have to take it to the dealer now to get it re-filled? I just had them pump / flush / change it.
Thanks for any help you can provide...
Old Apr 30, 2016 | 04:10 AM
LtLeary's Avatar
Yes, that is cvt fluid. When re-installing don't forget to get a new seal for the axle shaft. Replacing the fluid is straight forward, remove the transmission "dip stick" from the filler neck, add some NS-2. Do not over fill and measure after cvt is warm!
Old Apr 30, 2016 | 05:33 AM
14blackbeauty's Avatar
exactly what LT said, Do not cheap out do the seal or when it leaks you will have to do the whole job again!
matts95max
Apr 27, 2023 05:44 AM
brichi
Apr 14, 2016 07:27 PM
mrdigray
Apr 11, 2016 02:46 PM
NRAsteveo
Apr 7, 2016 08:33 PM
Noela
Apr 1, 2016 06:26 AM
