Rear Door Finisher/Panel Removal
Old Mar 18, 2017 | 03:27 PM
Max12LE's Avatar
Anyone ever seen a video or a step by step with pics for removing the rear door finisher panel for a 2009-14 Maxima? I need to replace the door lock actuator but it's puzzling on where to access the panel screws. I know the door handle removal reveals the top 10mm bolt but after that, what's the procedure? If you have the section labeled "INT" for the 2009-14 Maxima service manual (the free download has it absent for some reason?), I'd be grateful for that.
I'm also assuming I'd want to disconnect the negative on the battery. The door lock no longer locks/unlocks with the key fob, you have to manually flip the door lock. While that's not a big deal, I'm about to sell the car and apparently this is a deal breaker for them that it doesn't work.
Thanks in advance.
