Torque specs for rear brake
Old Nov 6, 2017 | 07:47 AM
Albert's Avatar
What are the torque specs for the rear caliper slider bolt (14mm) and for the caliper mounting bolt (19mm) on a 2014 Maxima?
Old Nov 6, 2017 | 09:35 AM
MadMax07SL's Avatar
Seems like a reasonable question. But I'll be honest, I've never torqued anything in my life, always quality tight with the right length wrench. Do it enough times and you just know. I'd recommend torqueing anything involving the engine head/valve covers, anyplace where damaged threads means a major part replacement. but for the brakes, it's just wrench tight, don't forget the Loctite to be sure it doesn't come loose from vibrations.
Old Nov 7, 2017 | 06:34 AM
LtLeary's Avatar
32 for sliding bolt and 62 for the cage
Old Nov 14, 2017 | 11:02 AM
2Soonjr's Avatar
wow, only 32?
