Wheel Adapters for 09?
Old May 7, 2018 | 06:21 PM
Ashabhi's Avatar
Hi
i have a 09 with stock tires setup ie 245 45 r18.
i researched a lot and decided to go for hub centric wheel adapters rather than generic wheel spacers.
how much mm size should i go for such that i have no rubbing and it'll be good for Canadian winters. (-10 degrees celcius to -35 degrees celcius)
i am confused between 25mm and 30mm.
I'm planning to have wider adapters in the back because of the beefy fenders.
PS this is a daily driven not just for car shows.
Old Jun 28, 2019 | 02:21 PM
86'ed's Avatar
Bring this back to life... I too have a similar question(s) about adapters.
I got a good deal on some Rohana's but they are 5x120. Local shops around my area are charging $100+ per rim to re-drill. Any suggestions would help.
Old Jun 28, 2019 | 04:22 PM
VeeQue35DE's Avatar
You can buy an adapter that goes from 5x120 to 5x114 but you'll also need a hub centric ring that goes 66.2mm to w/e the bore of the adapter is. Otherwise you may feel vibrations while driving at higher speeds.
tgood
Jan 30, 2013 06:23 AM
playboi21617
Tires and Wheels
Jan 27, 2008 04:56 PM
maxspeed96CT
Tires and Wheels
Mar 12, 2004 05:04 PM
sanjosemaxima
Tires and Wheels
Jun 18, 2003 06:37 PM
