Help with P2A00 code
Old Apr 28, 2019 | 11:06 AM
Nestorsh's Avatar
Hi, so I had the engine light on, and I pulled the code “P2A00” which is sensor 1 bank 1, so I replaced and the light went off, but after couple days the light came back on!! With the same code, anyone know something about it?
Old Apr 28, 2019 | 11:59 AM
Richard66's Avatar
https://www.engine-codes.com/p2a00_2...an_maxima.html
You might start here.
Old May 9, 2019 | 08:02 AM
Nestorsh's Avatar
I took the car to the dealer and they told me is the sensor, they said that sensors from Autoparts are garbage, even if is a Denso. hes trying to make me pay 500 for a Nissan/Denso. Have you heard of this?
Old May 9, 2019 | 01:36 PM
Richard66's Avatar
Is that 500 parts and labor or for just the part? Do you know what the Nissan part number is?
Old May 9, 2019 | 01:54 PM
LWilspeed's Avatar
Hard to say. For sure you can have this issue on aftermarket coil packs, I don't know about that sensor. On a different note, which sensor did you replace (mass air, upstream o2, downstream 02 or something else)? Have you had any other work done recently on the car? It's possible you can have some kind of air leak causing the code, faulty electrical, etc. Also, there is an interesting post on a sentra forum about the downstream sensor having to be replaced when the code was indicating an upstream sensor fault. Totally different setup I know, but interesting thought.
Old May 9, 2019 | 04:38 PM
Nestorsh's Avatar
Part and labor, I checked the price on Nissan webpage and was around 300, (i paid 90 with coupons on advance autoparts)
Old May 9, 2019 | 07:44 PM
User1's Avatar
Denso is an OEM provider for Toyota and Nissan, among others, I'm sure.
Old May 10, 2019 | 04:07 AM
Nestorsh's Avatar
It is, but the dealer said the parts they make for other than Nissan are junk. No sure if I can believe that...
Old May 10, 2019 | 04:12 AM
Nestorsh's Avatar
I replaced the Rear Upstream (b1s1). I recently replaced transmition and power steering system, and oil changes.
Old May 23, 2019 | 08:32 PM
VeeQue35DE's Avatar
You already changed bank 1 sensor 1 sensor so next in line is checking for vacuum leaks and fuel pressure. Vacuum gauge and fuel pressure gauge.
Old Jun 7, 2019 | 10:01 AM
Nestorsh's Avatar
Dealer keeps telling me its the sensor, they said the heater element on aftermarket sensors are always bad ( I used a Denso from Advance) so, they wanna charge me 500$ for a new sensor and labor!
But before doing that, is there any way to test the sensor that I have to make sure its the sensor, I have the feeling that they just trying to rip me off.
Also, how do I check for vacuum leaks?
Old Jun 7, 2019 | 12:30 PM
Nestorsh's Avatar
Here with more details of my problem:
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 5.9%
ENG SPEED: 800RPM
BARO PRS: 30.1 “HG
CALC LOAD: 36.5%
MAF: 0.76 LB/M
COOLANT: 199 DEGF
IAT: 129 DEGF
IGN ADV: 11.0 DEG
ST FTRM1: 14.1%
ST FTRM2: -1.6%
LT FTRM1: 9.4%
LT FTRM2: -0.8%
VEH SPEED: 0MPH
ABS LOAD: 27.5%
FUEL SYS 1: CLOSED
FUEL SYS 2: CLOSED
REL TPS: 3.5%
THROT CMD: 6.3%
ABS TPS B: 5.9%
ACC POS D: 0.0%
ACC POS E: 0.0%
CAT TEMP11: 716 DEGF
CAT TEMP21: 716 DEGF
EVAP PURGE: 0.0%
EVAP VP: 0.000 H2O
CMD EQ RAT: 0.870
O2S B1S2: 0.000V
O2S B2S2: 0.710V
O2S B1S1: 0.830V
EQ RAT B1S1: 0.874
EQ RAT B2S1: 1.007
O2S B1S1: 2.365V
MIL TIME: 00:00
CLR DIST: 558MI
CLR TIME 31:24
CLR TRPS: 41
MIL DIST: 0MI
FUEL LEVEL: 69.8%
VPWR: 14.320V
ENG RUN: 40:22
I really hope someone can help me.
Old Jun 7, 2019 | 01:19 PM
VeeQue35DE's Avatar
I've seen many cases when new parts arrive and are faulty. You could have a defective sensor, in which case I'd get it swapped with another one. I doubt they'll bench test the sensor to determine if it's faulty or not and if they do, then they can confirm if it is a working unit. If you really want a OEM sensor then the part number is 22693-ZX70A and you can have an outside shop install it instead of the dealer. The O2 Bank 1 Sensor 1 for 7th Gen flat rate runs 0.9 labor hours according to ProDemand. You'll be looking to spend approximately ~$125 in labor alone from an outside shop. Dealerships have different pricing grids and I'm not sure what Nissan's is.
Your Bank 1 Sensor 1 Long Term trims are pretty high so I can see how that triggered a leak code. It's pumping more fuel to compensate for the extra air being sucked in somewhere in the system. MAF intake and O2 output values don't match and O2 is the major sensor when in closed loop. Everything else is around or near stoichometric values.
For the leaks you can use either a smoke machine, a vacuum gauge, or a can of propane. The smoke machine is the easiest but expensive to own unless you run your own business. A Vacuum gauge tells you if you actually have a leak but won't pinpoint where.
The propane test would be the most precise since propane molecules are just big enough to sneak into vacuum leaks. Attach a hose and a metering valve to a propane bottle and let a small amount leak around the intake area while the car is running. Keep an eye on the fuel trim values, especially STFT 1. Trace around the mating areas of the intake manifold and throttle body with the propane and when you see the values change, that's where the leak is. The propane would make the trims seem even richer because it's fuel added to the fire.
Old Jun 7, 2019 | 01:24 PM
Nestorsh's Avatar
thing is that I already exchange the sensor twice at advance auto parts, I'm really skeptical about being the sensor, I have the feeling is something else. And OEM cost 350$ I dont wanna pay that and get the code again.
Old Jun 7, 2019 | 02:52 PM
VeeQue35DE's Avatar
You could try to cut a deal with your Nissan service adviser, if the $500 fix doesn't get rid of the check engine light then ask for a discount on labor if the same code pops up and it turns out to be something else. If the adviser said that the O2 sensor is the only thing causing the code and nothing else then have him note that on your repair order since it's a legal contract. Otherwise, it was misdiagnosed by the technician and not fair that you should incur the full labor charge because it should've been diagnosed and corrected the first time. I say ask for labor discounts because the part itself isn't expensive but the labor for manifold gaskets is around 2 hours.
Old Jun 11, 2019 | 08:44 AM
Nestorsh's Avatar
I have a big problem for that, Im lost about the vacuum lines, I do not know which lines belong to vacuum. I havent been lucky to find any picture or info online.
Old Jun 11, 2019 | 01:10 PM
VeeQue35DE's Avatar
The vacuum lines are all the lines attached to the intake manifold (main source of pressure Hg / vacuum) but keep in mind that vacuum leaks come from either hoses or gaskets. Also do not mistake the lines from the throttle body for vacuum lines,
Old Jun 11, 2019 | 01:42 PM
Nestorsh's Avatar
Great, that’s a lot of help, I’ll try that method I hope that’s my problem...
Old Jun 11, 2019 | 02:14 PM
Nopike's Avatar
I would not believe a damn thing a Nissan dealer tells me. I'm sure the Denso parts from Advance are just as good if not better than anything the dealer is selling.
Old Jul 1, 2019 | 05:10 AM
Nestorsh's Avatar
Well, I'm still fighting with this issue
I took my car for smoke test and they found no leaks...
my scanner is reading oxygen sensors monitor incomplete, I been driving for miles and miles and I just cant get the drive cycle ready, but now Im getting P0171
RPMs are little high (round 800-100) no car hesitation or rough idle, I have a weird smell but no other symptoms. I had upstream (b1 & b2) oxygen sensors replaced, I cleaned my MAF sensor with proper cleaner. And I just cant find a solution to this problem.
Dealerships keeps telling me is the Oxygen sensor, which I replaced already with a Denso from autoparts, Nissan said Sensors from Autoparts are junk, and that I need to get one from them which is $350!! plus labor... had anyone experienced something like that?
Old Jul 1, 2019 | 10:44 AM
Nopike's Avatar
Have you checked the FSM? There is information in the FSM on the P0171 that may be useful. I hope your Nissan dealer is better than the ones I have had experience with. Most of them can't even do the simple repairs correctly.
https://nicoclub.com/FSM/Maxima/2014%20Maxima/EC.pdf
Old Jul 1, 2019 | 11:45 AM
Nestorsh's Avatar
yes i did checked... but inicially had P2A00 but now i have P0171, I've tried some stuff but nothing yet.
Old Jul 1, 2019 | 12:16 PM
VeeQue35DE's Avatar
Old Jul 1, 2019 | 12:41 PM
Nestorsh's Avatar
Meaning is time to change MAF sensor? I should be able to buy one from advance autoparts and use it without problems right? Or I have to buy it from the dealer? Also, I've read that if the MAF sensor were bad I'll have both banks lean. What do you think?
Old Jul 1, 2019 | 01:59 PM
VeeQue35DE's Avatar
The graph I showed you are the most common fixes for that trouble code and most point towards the MAF, but it's strange that your car is giving you code after code. If the MAF was faulty then it would show in both sensors, like you said, unless the moment that the code is triggered is during a certain driving situation. Then it may be the vacuum actuators on the plenum not moving properly. They're supposed to move according to the needs of the engine. You'd need a scan tool that has a snap shot feature to take images of when the code is triggered and what values pop up at that moment.
Are there any modifications you've done to the engine to change flow? Intake, Exhaust, Headers, block off plates, etc.
Old Jul 1, 2019 | 03:34 PM
Nestorsh's Avatar
Nope, any mods... and i do have a scan tool, I can post the freeze data, or wherever is called.
update:
just got a new maf sensor and I tried and... NOTHING! Fuel trims are same, rpms high and everything same
Im about to quit and take it to the stealership!
Old Jul 2, 2019 | 10:45 AM
Nestorsh's Avatar
MIL STATUS: ON
TROUB CODE: P0171
ABSLT TPS: 5.5%
ENG SPEED: 788RPM
BARO PRS: 102.0 KPa
CALC LOAD: 27.8%
MAF: 4.58 gr/S
COOLANT: 92 DEGF
IAT: 62 DEGF
IGN ADV: 14.0 DEG
ST FTRM1: 0.0%
ST FTRM2: -1.6%
LT FTRM1: 0.0%
LT FTRM2: -0.8%
VEH SPEED: 0MPH
ABS LOAD: 20.4%
FUEL SYS 1: Open-Fault
FUEL SYS 2: CLOSED
REL TPS: 3.9%
THROT CMD: 5.5%
ABS TPS B: 5.5%
ACC POS D: 0.0%
ACC POS E: 0.0%
CAT TEMP11: 244 DEGF
CAT TEMP21: 244 DEGF
EVAP PURGE: 0.0%
EVAP VP: 0.000 Pa
CMD EQ RAT: 0.870
O2S B1S2: 0.000V
O2S B2S2: 0.280V
O2S B1S1: 0.915V
EQ RAT B1S1: 0.887
EQ RAT B2S1: 0.992
O2S B1S1: 2.320V
MIL TIME: 00:00
CLR DIST: 238 Km
CLR TIME 07:05
CLR TRPS: 8
MIL DIST: 0 km
FUEL LEVEL: 42.0%
VPWR: 14.320V
ENG RUN: 32:08
Old Jul 2, 2019 | 01:59 PM
VeeQue35DE's Avatar
update:
A better snap shot would be with the vehicle moving and the moment the DTC is triggered. You may need a helper with you if your scan tool doesn't support the function. Erase the DTC and make sure the check engine light is off. Drive around with a partner and have him take a snap shot when the check engine light turns on.
Also, did you perform the fuel ratio relearn when you installed the new MAF?
MIXTURE RATIO SELF-LEARNING VALUE CLEAR : Special Repair Requirement INFOID:0000000005463403
With GST (Generic Scan Tool)
1. Start engine and warm it up to normal operating temperature.
2. Turn ignition switch OFF.
3. Disconnect mass air flow sensor harness connector.
4. Restart engine and let it idle for at least 5 seconds.
5. Stop engine and reconnect mass air flow sensor harness connector.
6. Select Service $03 with GST. Check that DTC P0102 is detected.
7. Select Service $04 with GST to erase the DTC P0102.
But even after the procedure it might not fix your problem. Like you said earlier, both O2 sensors should show an incorrect value if the MAF were the problem. What's strange is the Open Loop in Fuel Sys1 connected to B1S1 O2 sensor. The PCM still thinks the Bank 1's system is still wrong so it's ignoring fuel correction, which is why it shows values of 0.0% for ST and LT fuel trims1, BUT the 0.915V is rather high for a vehicle @ idle which indicated rich conditions. That kind of voltage is what you'd see if your engine load was around 80-90+%. B2S2 shows that it's trimming back on fuel, which shows that it's running a bit on the rich side. It may be that it's unable to control fuel flow but fuel rail dampers and injectors rarely go bad. This one is a head scratcher for sure... B1 and B2 have their own fuel dampers / regulators.
Your MAF values are good @ idle, within 2.0 - 6.0 grams/sec @ idle, and it should be 7.0 - 20.0 grams/sec @ 2500RPM.
Old Jul 2, 2019 | 05:07 PM
Nestorsh's Avatar
yes, I been struggling with this for a couple months. Freaking mechanics around here suck, I really don’t know what to do to at this point. Right now I’m waiting till I don’t get any monitor incomplete make sure that p2a00 code won’t come back. I did the Relearn but the readings were the same.
Old Jul 5, 2019 | 07:40 AM
Nestorsh's Avatar
Is there any way to test the air/fuel ratio sensor to see if thats the real problem?
Old Jul 5, 2019 | 01:54 PM
VeeQue35DE's Avatar
Old Jul 8, 2019 | 08:00 AM
Nestorsh's Avatar
Here I am, again
last freeze frame, with all the modules complete, P0171 is gone, but i still get P2A00. I Tried the live data while car is moving but my scanner disconnects as soon I car start moving. (U-scan - Actron)
I'll get me a torch to test my o2 sensor.
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 4.7%
ENG SPEED: 700RPM
BARO PRS: 102.0 KPa
CALC LOAD: 29.0%
MAF: 4.12gr/S
COOLANT: 91 DEGC
IAT: 42 DEGC
IGN ADV: 10.0 DEG
ST FTRM1: 9.4%
ST FTRM2: -15.6%
LT FTRM1: 9.4%
LT FTRM2: 9.4%
VEH SPEED: 0 KPH
ABS LOAD: 21.2%
FUEL SYS 1: CLOSED
FUEL SYS 2: CLOSED
REL TPS: 4.3%
THROT CMD: 4.7%
ABS TPS B: 4.7%
ACC POS D: 0.0%
ACC POS E: 0.0%
CAT TEMP11: 320 DEGC
CAT TEMP21: 320 DEGC
EVAP PURGE: 0.0%
EVAP VP: 0.000 H2O
CMD EQ RAT: 0.870
O2S B1S2: 0.040V
O2S B2S2: 0.790V
O2S B1S1: 0.895V
EQ RAT B1S1: 0.867
EQ RAT B2S1: 1.008
O2S B1S1: 2.340V
MIL TIME: 00:00
CLR DIST: 105 KM
CLR TIME 02:40
CLR TRPS: 5
MIL DIST: 0KM
FUEL LEVEL: 100.0%
VPWR: 14.320V
ENG RUN: 13:11
Old Jul 12, 2019 | 11:31 AM
Nestorsh's Avatar
This is the snap shot when the light came back on. I don't know if that will tell something, I am really stress about it...I will have a long trip soon and Im afraid something will go bad.
Thank you!
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 9.4%
ENG SPEED: 1475RPM
BARO PRS: 102.0 KPa
CALC LOAD: 43.9%
MAF: 15.02gr/S
COOLANT: 90 DEGC
IAT: 38 DEGC
IGN ADV: 33.0 DEG
ST FTRM1: 15.6%
ST FTRM2: -7.0%
LT FTRM1: 0.0%
LT FTRM2: 0.0%
VEH SPEED: 80 KPH
ABS LOAD: 40.0%
FUEL SYS 1: CLOSED
FUEL SYS 2: CLOSED
REL TPS: 7.8%
THROT CMD: 9.8%
ABS TPS B: 4.7%
ACC POS D: 8.6%
ACC POS E: 8.6%
CAT TEMP11: 480 DEGC
CAT TEMP21: 480 DEGC
EVAP PURGE: 0.0%
EVAP VP: 0.000 Pa
CMD EQ RAT: 0.870
O2S B1S2: 0.020V
O2S B2S2: 0.710V
O2S B1S1: 0.865V
EQ RAT B1S1: 0.869
EQ RAT B2S1: 1.000
O2S B1S1: 2.330V
MIL TIME: 00:00
CLR DIST: 129 KM
CLR TIME 04:22
CLR TRPS: 10
MIL DIST: 0KM
FUEL LEVEL: 44.3%
VPWR: 14.400V
ENG RUN: 21:01
Old Jul 16, 2019 | 02:43 PM
VeeQue35DE's Avatar
Thank you!
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 9.4%
ENG SPEED: 1475RPM
BARO PRS: 102.0 KPa
CALC LOAD: 43.9%
MAF: 15.02gr/S
COOLANT: 90 DEGC
IAT: 38 DEGC
IGN ADV: 33.0 DEG
ST FTRM1: 15.6%
ST FTRM2: -7.0%
LT FTRM1: 0.0%
LT FTRM2: 0.0%
VEH SPEED: 80 KPH
ABS LOAD: 40.0%
FUEL SYS 1: CLOSED
FUEL SYS 2: CLOSED
REL TPS: 7.8%
THROT CMD: 9.8%
ABS TPS B: 4.7%
ACC POS D: 8.6%
ACC POS E: 8.6%
EVAP PURGE: 0.0%
EVAP VP: 0.000 Pa
CMD EQ RAT: 0.870
O2S B1S2: 0.020V
O2S B2S2: 0.710V
O2S B1S1: 0.865V
EQ RAT B1S1: 0.869
EQ RAT B2S1: 1.000
O2S B1S1: 2.330V
MIL TIME: 00:00
CLR DIST: 129 KM
CLR TIME 04:22
CLR TRPS: 10
MIL DIST: 0KM
FUEL LEVEL: 44.3%
VPWR: 14.400V
ENG RUN: 21:01
The numbers showing up on your car contradict itself. LTFT being 0 means no adjustment has been made and is running "perfectly" but the ST being in double digits should've moved the LT even a little (0.1) in the 21mins you've been running the car and you still have a P2A00 active code. At this point the best route would be the dealer. Their diagnostic tools should be able to better pinpoint the problem. They also have oscilloscopes to test injector pulse widths and ignition timing box wave patterns, and wideband O2 sensor testers.
Old Jul 22, 2019 | 10:45 AM
Nestorsh's Avatar
I did took the car to the dealer this weekend, they replaced the "B1S1 Air/Fuel Ratio Sensor". After I got home I took a look and they replaced that one that is closer to the front bumper, I believe they replaced the wrong one, unless I'm wrong, as I know a 2009 Maxima bank 1 should be the closest to the firewall and bank 2 closest to front bumper, right? Please someone tell me if I'm wrong.
Old Aug 1, 2019 | 10:12 AM
Nestorsh's Avatar
So, I was right, they replaced the wrong sensor :/ I took it back to the dealer and they installed the correct one. So now I have both sensors new (OEM), but engine light still on
Whats next?
LAST REPORT:
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 5.9%
ENG SPEED: 775RPM
BARO PRS: 102.0 KPa
CALC LOAD: 36.9%
MAF: 5.55gr/S
COOLANT: 92 DEGC
IAT: 58 DEGC
IGN ADV: 11.0 DEG
ST FTRM1: 14.1%
ST FTRM2: -0.8%
LT FTRM1: 9.4%
LT FTRM2: -3.1%
VEH SPEED: 0 KPH
ABS LOAD: 27.5%
FUEL SYS 1: CLOSED
FUEL SYS 2: OPEN DRIVE
REL TPS: 3.5%
THROT CMD: 5.9%
ABS TPS B: 5.9%
ACC POS D: 0.0%
ACC POS E: 0.0%
CAT TEMP11: 300 DEGC
CAT TEMP21: 300 DEGC
EVAP PURGE: 0.0%
EVAP VP: 0.000 Pa
CMD EQ RAT: 0.870
O2S B1S2: 0.000V
O2S B2S2: 0.850V
O2S B1S1: 0.895V
EQ RAT B1S1: 0.876
EQ RAT B2S1: 0.993
O2S B1S1: 2.175V
MIL TIME: 00:00
CLR DIST: 75 KM
CLR TIME 02:48
CLR TRPS: 7
MIL DIST: 0KM
FUEL LEVEL: 2.4%
VPWR: 14.240V
ENG RUN: 16:14
Old Aug 1, 2019 | 09:25 PM
BronxSleeperMax187's Avatar
Whats next?
LAST REPORT:
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 5.9%
ENG SPEED: 775RPM
BARO PRS: 102.0 KPa
CALC LOAD: 36.9%
MAF: 5.55gr/S
COOLANT: 92 DEGC
IAT: 58 DEGC
IGN ADV: 11.0 DEG
ST FTRM1: 14.1%
ST FTRM2: -0.8%
LT FTRM1: 9.4%
LT FTRM2: -3.1%
VEH SPEED: 0 KPH
ABS LOAD: 27.5%
FUEL SYS 1: CLOSED
REL TPS: 3.5%
THROT CMD: 5.9%
ABS TPS B: 5.9%
ACC POS D: 0.0%
ACC POS E: 0.0%
EVAP PURGE: 0.0%
EVAP VP: 0.000 Pa
CMD EQ RAT: 0.870
O2S B1S2: 0.000V
O2S B2S2: 0.850V
O2S B1S1: 0.895V
EQ RAT B1S1: 0.876
EQ RAT B2S1: 0.993
O2S B1S1: 2.175V
MIL TIME: 00:00
CLR DIST: 75 KM
CLR TIME 02:48
CLR TRPS: 7
MIL DIST: 0KM
FUEL LEVEL: 2.4%
VPWR: 14.240V
ENG RUN: 16:14
What did they say? Maybe it needs to be driven until the cpu notices and it will reset its self after a good cycle.... ask questions next time lol
Old Aug 2, 2019 | 04:51 AM
Nestorsh's Avatar
they cleared the code, after a drive cycle the light came back, Im looking to see if anyone else had/has this kind of issue, since my closer dealer is a joke maybe someone here knows about it.
Old Aug 4, 2019 | 05:54 AM
Do you have an air intake other than stock oem ? Run some fuel injector cleaner and MAF cleaner...maybe one is clogged up....999MP-FSC00P.....start cheap and work you're way up......PCV,Coils, Injectors, MAF.....good luck, and see if the mechanic can check it for free since it came back.
Old Aug 5, 2019 | 10:37 AM
Nestorsh's Avatar
No mods in intake or anything, I already run injector cleaner twice, cleaned MAF sensor, PCV replaced, vacuum lines replaced, dealer just changed AF sensors (upstream b1 & b2)
but I still have the light. they did a "diagnosis" again, and they came with 5000$ to fix it lol they said I need to replace my cats.. 5000, seriously?!
Im about to give up and just drive and wait ...
I noted something in last data freeze.
MIL STATUS: ON
TROUB CODE: P2A00
ABSLT TPS: 3.5%
ENG SPEED: 612RPM
BARO PRS: 101.0 KPa
CALC LOAD: 23.5%
MAF: 2.76gr/S
COOLANT: 91 DEGC
IAT: 56 DEGC
IGN ADV: 14.0 DEG
ST FTRM1: 14.1%
ST FTRM2: 0.8%
LT FTRM1: 9.4%
LT FTRM2: -3.1%
VEH SPEED: 0 KPH
ABS LOAD: 17.3%
FUEL SYS 1: CLOSED
FUEL SYS 2: CLOSED
REL TPS: 3.5%
THROT CMD: 3.1%
ABS TPS B: 3.5%
ACC POS D: 0.0%
ACC POS E: 0.0%
CAT TEMP11: 164 DEGC MECHANIC AT DEALER SAID CAT TEMPS WERE DIFFERENT AND THEY SHOULD BE THE SAME, BUT MY SCANNER SHOWS SAME TEMP.
CAT TEMP21: 164 DEGC
EVAP PURGE: 0.0%
EVAP VP: 0.000 Pa
CMD EQ RAT: 0.870
O2S B1S2: 0.000V is this normal? also, where is O2S B2S1?
O2S B2S2: 0.670V
O2S B1S1: 0.740V
EQ RAT B1S1: 0.859
EQ RAT B2S1: 1.004
O2S B1S1: 2.270V
MIL TIME: 00:00
CLR DIST: 124 KM
CLR TIME 03:17
CLR TRPS: 3
MIL DIST: 0KM
FUEL LEVEL: 38.0%
VPWR: 14.240V
ENG RUN: 17:57
