Squealing/ grinding noise when making turn
Old Aug 9, 2020 | 02:42 PM
Scoonie05's Avatar
My car makes a squealing/grinding noise only when I'm making a hard turn. If I make a turn where I don't turn the wheel all the way, it don't make a noise. In guessing the power steering pump. Any help is greatly appreciated. Thanks
Old Aug 9, 2020 | 02:58 PM
Vinar's Avatar
First thing to do would be check power steering fluid level. if it is low it will make that happen. if you fill it up and it still does it probably starting to fail.
Old Aug 9, 2020 | 03:50 PM
Scoonie05's Avatar
I just checked the fluid. It was over filled. It's cold and the fluid level is over the hot max line. So I took some out to get it to the max cold line. Problem still exists
Old Aug 9, 2020 | 06:44 PM
MaximusN8's Avatar
Did you recently do work to you steering system? If so it's possible you got air in the system or your pump is on it's way out! I would get that checked much sooner than later, Or steering is going to be a job in its self!
Old Aug 10, 2020 | 03:22 AM
Scoonie05's Avatar
I think you're on to something. I saw the reservoir bubbling the other day. I guess that means air is in the system? I had my alternator done in January
Pnjboyzz
May 12, 2015 12:40 PM
95GhostMax
Aug 19, 2003 01:25 PM
MaXBoost03_SE
May 15, 2003 01:08 PM
