How much power steering fluid the system holds?
Old Feb 26, 2021 | 07:37 PM
mahanddeem's Avatar
Hello,
How much hydrolic fluid the power steering system holds in the 7th gen? I have a 2009
I'm thinking about changing that fluid.
Old Feb 26, 2021 | 08:14 PM
Les7311's Avatar
Am also interested to know
i believe a quart?
let’s see....
Old Feb 27, 2021 | 01:08 PM
2young2retire's Avatar
Here is some info you may be able to use.
File Type: pdf
Old Feb 27, 2021 | 02:44 PM
Les7311's Avatar
Good stuff 2Young
Old Feb 27, 2021 | 03:27 PM
Vinar's Avatar
Best way to do it is disconnect the return line from reservoir and attach a 5/8 inch hose. I used a clear one so I could see when all the old fluid was flushed out. Helps to have a friend to pour it in don't wanna get air in the lines. Also turn the wheel lock to lock slowly 10-20 times with engine off.
Old Feb 27, 2021 | 08:41 PM
User1's Avatar
Engine off just fills the rack, which is already full. He needs engine on. Lock-to-lock until res low, fill res, lock-to-lock til low, refill, etc.. Repeat til you're happy with the color of fluid, button it up and crack a cold one.
Old Mar 24, 2021 | 01:50 PM
jamarsmalls25@icloud.com's Avatar
I replaced it on my high pressure hose and now like the side that connects to the rack opinion it leaks. When I start the car it pours straight out and Reservoir will be empty I did it like six times and change it two different hoses I still get the same thing i’m pretty sure I’m putting it in right and tight enough because it’s so tight and I’ve been doing it so many times I have been stripping the bolt!
can anybody tell me what am I doing wrong or did I miss something before connecting it all the metal washes on both sides of the holes so I don’t know. I really need help because it’s really frustrating me and I’ve been working on this for like a week now any advice?
arthur glazier
Apr 8, 2009 12:07 AM
Dan
Apr 10, 2005 04:22 PM
DaBombX
Mar 21, 2004 02:51 PM
MaxKlinger
Feb 17, 2004 10:35 AM
rcy
Jun 3, 2003 01:37 PM
