Shakes after mount replacement
Old Apr 27, 2021 | 11:05 AM
superkeith's Avatar
2010 Maxima had a bad front mount so I replaced all the engine/transmission mounts now it’s shaking under acceleration. When the mount broke It started shaking that’s the reason for replacing them. I think maybe axles but looking to see if anyone else had this issue.
Old Apr 27, 2021 | 05:26 PM
TDGrant's Avatar
Check the nuts/bolts on your mounts. Something is loose.
Also, put someone in the car, have their foot on the brake while putting the car in drive/park/reverse, and you looking at the engine bay to see where excessive movement is coming from.
Old Apr 28, 2021 | 05:34 AM
superkeith's Avatar
I did all that everything is tight as a drum. At slow speed I can see the wobble going side to side faster I go worse it gets like axle is pushing against it. I think when I raised the engine to align rear mount bracket I could of went too high and now axle is binding on passenger side. Anyone else have this issue?
user name001
Jun 11, 2012 09:57 AM
2k1maxgle
Feb 22, 2008 11:45 AM
maximase86
Apr 7, 2003 08:37 AM
Tom
Dec 19, 2000 08:34 PM
