CVT Filter 2009 350Ti
Other members talking about the external filter for the CVT transmission. Part number 31726-1XE0A. Australian Nissan dealer has no such part or description listed. Can anyone tell me the Australian part number or do I just need to order it from another country?
Not sure why Australia would have a different PN but the description here in the US is oil filter. Not cvt or transmission filter. Just because i am curious, do you even have the filter in the drivers side wheel well like the US version?
here you have: http://brettsfilters.com.au/p/936903...17261xe0a.html
If my math is correct, that comes out to $125!!! Wow!
Originally Posted by LtLeary
(Post 9252872)
Originally Posted by q_nerk
(Post 9252880)
(Post 9252883)
Amazon!
I was able to find the external CVT filter on Amazon for around $75. i usually just use Valvoline's CVT fluid but will be switching to Amsoil.
Do let us know how the valviline/amsol route works for you. I havent seen any high mileage posts with anyone going that route so am curious.
I purchased it used at 70,000. 2009 SV. I've changed the fluid pretty religiously every 15k. I have 163,000 now. Valvoline fluid every time and am just now considering changing the filter as it is getting older. No lights on dash, drives great, and we will die together if I have it my way! Just been hearing good things about the Amsoil fluid is all.
(Post 9252872)
https://cimg7.ibsrv.net/gimg/maxima....cabb0d0d76.jpg vers side wheel well like the US version? |
31728-29x0d. But that is just the strainer. Not the gasket or bolts (yes, the fsm calls for replacing the pan bolts after dropping the pan.)
(Post 9253181)
Wow to replacing pan bolts. Thanks for letting me know but I will inspect pan bolts and re use if they look OK. I will remove pan and see if strainer is a serviceable item. Clean, blow it out and reuse. Dealer could not even confirm there was a strainer there by looking at the exploded diagram. I will put 2 more 4 litres of NS-3 through it over the next four weeks and hopefully I never hear a peep out of what is a smooth running cvt at 173000 km. |
(Post 9253181)
Close up of black sludge around pan magnets. Fitted new external filter and have cleaned pan out. Also removed and cleaned valve body strainer and refitted. I will remove once again when pan gasket turns up. Will also put my 3rd 4 litre tin of NS-3 tranny fluid through it after changing gasket. Original gasket looks good for multiple pan removals so $60 new gasket will only be used at final clean and replacement. Anyone know the torque settings for valve body strainer bolts and pan? https://cimg5.ibsrv.net/gimg/maxima....7606db63f5.jpg Pics for those interested. Black sludge in pan after pan removal. |
The pan is 8.1nm or 72 inch lbs. Not seeing the strainer torque specs.
Originally Posted by Wozmax
(Post 9253187)
Gasket is on its way at AUD$60.
Wow to replacing pan bolts. Thanks for letting me know but I will inspect pan bolts and re use if they look OK. I will remove pan and see if strainer is a serviceable item. Clean, blow it out and reuse. Dealer could not even confirm there was a strainer there by looking at the exploded diagram. I will put 2 more 4 litres of NS-3 through it over the next four weeks and hopefully I never hear a peep out of what is a smooth running cvt at 173000 km. Though aftermarket fluids seem to not care as they list both NS2 and NS3 in their compatibility list. |
(Post 9253322)
7th gen Maxima (your 2009) should call for NS2 Nissan CVT fluid why NS3?
(Post 9253333)
NS-3 is back compatible and I suppose one could argue it meets higher specifications than NS-2. Besides that it is what the local Nissan dealer supplied me for about AUD $78 per 4 litre can.
http://www.nissantechnicianinfo.mobi...vice_Tips.html Notably: "NISSAN CVT Fluid NS-2 (“green fluid”) – applies to all Nissan vehicles equipped with a CVT built prior to 2013. Use NS-2 green fluid to service these vehicles.New, unused service replacement CVTs may have some residual “blue” NS-3 fluid. However, these service replacement CVTs should be filled with NS-2 green fluid. No draining is necessary." |
(Post 9253334)
I have a reference Nissan strictly calls for NS2 for 2009 to 2014 Maximas even though NS3 has been there for several years. The language they use is clear they do not want NS3 in these CVTs.
(Post 9253342)
ok noted and thank you. When I questioned the local dealer he just said it is back compatible. I will take it up with them. Appreciate the info. I will be very pissed off if they have stuffed this up.
(Post 9253343)
Phoned dealer and they insist NS-3 is the current cvt fluid for that car. Rang a different dealer in Brisbane (Capital of Queensland) they agreed NS-3 listed for my car. I mentioned the Nissan technical note and they still said NS-3. Local Nissan dealer said they cant get NS-2 anymore. Wondering if an old note and it was issued to make sure all stocks of NS-2 used up first?
When I visit dealership, I ask for NS2. I wouldn't ask what CVT fluid suits my Maxima 2009. It's also written everywhere you look inside the hood in bold fonts. As well as service manuals and Owner's manual. Unless something big happened with CVT fluid formulation, which I honestly doubt. Anyway, aftermarket cvt fluids (like Valvoline and Amsoil) list both on their certifications and approvals. Meaning you might me fine with either. NS3 has lower viscosity (lower cSt at 100c). |
© 2024 MH Sub I, LLC dba Internet Brands
