HELP! Want to debadge my car and do a chrome delete
Old Nov 7, 2016 | 12:24 PM
aradhakr84's Avatar
Hi Guys - Happy Monday!!! :P
I have finally convinced myself to debadge my silver max and do a chrome delete. Anyone from New Jersey know a reliable shop I can go for debadging and chrome delete.
Old Nov 7, 2016 | 04:52 PM
R1talin's Avatar
Do it yourself! much more rewarding and regardless if you go the plastidip or vinyl route for chrome delete you really cant screw it up. you just peel/pull it off and start again.
Debadging is easy, just get some fishing line to get the badges off and some goo-be-gone to clean up the remnants.
Good luck, whichever route you choose!
Old Nov 7, 2016 | 06:39 PM
DbrainX's Avatar
If you want to do it yourself, you might want to look into Autodip, it gives a gloss finish right away out of the can. I did my trunk piece and people cant tell the difference.
http://www.autodip.com/
Old Jan 13, 2021 | 07:43 AM
Miguel Bec Ramos's Avatar
[QUOTE=R1talin;9130845]Do it yourself! much more rewarding and regardless if you go the plastidip or vinyl route for chrome delete you really cant screw it up. you just peel/pull it off and start again.
Good luck, whichever route you choose![/QUOTE
but what do i use to mechanically take it off. Like a plastic blade or like what?
Old Jan 13, 2021 | 11:21 AM
compyelc4's Avatar
[QUOTE=Miguel Bec Ramos;9232971]
Hard nylon along with some GooGone would be best for the residual foam/adhesive. Consider using 91% denatured alcohol. Quite safe and you can leave it on much longer to soak in. Probably even better than GooGone.
Old Jan 14, 2021 | 08:53 AM
lindros2's Avatar
wonder if you can buy the 40th Anniversary parts - the only chrome is under the side windows.
Everything else - including door handles - is either black or body-color.
Old Jan 14, 2021 | 10:22 AM
robtroxel's Avatar
The nice thing about debadging is that you can make your Maxima be mistaken for an Altima. What a waste of time!
maxima0002
Detailing
May 28, 2004 07:08 PM
1HOTMAX
Detailing
Dec 8, 2003 06:33 PM
jag5311
May 15, 2002 04:36 PM
