Speaker wire diagram
Head unit wire harness diagram....
Hey guys so I'm going to completely overhaul the audio system in the non Bose s max and I know there is that thread where another member did a how to but I can't find out what color wires go to what speaker on the wiring harness. Anyone know this info or how to get it?
Might be able to get some info from the link below to a non Bose overhaul.
https://maxima.org/forums/8th-genera...light=non-bose
[img]content://com.samsung.android.email.attachmentprovider/1/261/RAW[/img]
FUNCTION
PIN
WIRE COLOR
Accessory 12 Volt
PK
Constant 12 Volt
20
GN
Chassis Ground
BODY
Power Antenna
BU on Ant Adapter *
Remote
Illumination (+)
RD
Dimmer (-)
GY
FUSE VALUE
FUSE LABEL
FUSEBOX LOCATION
20 AMP
"AUDIO"
DRIVER'S SIDE KICK PANEL
*The factory antenna booster is triggered by the BU wire on the antenna adapter. Connect to power antenna wire of new radio.
SPEAKER NOTES: Non-Bose system has speakers in the corners of dash and front doors (wired together in parallel for a 2.4-Ohm load) and rear doors and corners of rear deck (wired together in parallel for a 2.5-Ohm load).
Left Front Spkr +
GN
Left Front Spkr -
WT
Right Front Spkr +
18
PK
Right Front Spkr -
L.BU
Left Rear Spkr +
L.GN
Left Rear Spkr -
YW
Right Rear Spkr +
GN
Right Rear Spkr -
WT
Steering Wheel Controls
CAN-Bus, SWC interface coming soon
FUNCTION
PIN
WIRE COLOR
Accessory 12 Volt
PK
Constant 12 Volt
20
GN
Chassis Ground
BODY
Power Antenna
BU on Ant Adapter *
Remote
Illumination (+)
RD
Dimmer (-)
GY
FUSE VALUE
FUSE LABEL
FUSEBOX LOCATION
20 AMP
"AUDIO"
Left Front Spkr +
GN
Left Front Spkr -
WT
Right Front Spkr +
18
PK
Right Front Spkr -
L.BU
Left Rear Spkr +
L.GN
Left Rear Spkr -
YW
Right Rear Spkr +
GN
Right Rear Spkr -
WT
2020
FUNCTION
PIN
WIRE COLOR
Accessory 12 Volt
PK
Constant 12 Volt
20
GN
Chassis Ground
BODY
Power Antenna
BU on Ant Adapter *
Remote
Illumination (+)
RD
Dimmer (-)
GY
FUSE VALUE
FUSE LABEL
FUSEBOX LOCATION
20 AMP
"AUDIO"
Left Front Spkr +
GN
Left Front Spkr -
WT
Right Front Spkr +
18
PK
Right Front Spkr -
L.BU
Left Rear Spkr +
L.GN
Left Rear Spkr -
YW
Right Rear Spkr +
GN
Right Rear Spkr -
WT
FUNCTION
PIN
WIRE COLOR
Accessory 12 Volt
PK
Constant 12 Volt
20
GN
Chassis Ground
BODY
Power Antenna
BU on Ant Adapter *
Remote
Illumination (+)
RD
Dimmer (-)
GY
FUSE VALUE
FUSE LABEL
FUSEBOX LOCATION
20 AMP
"AUDIO"
Left Front Spkr +
GN
Left Front Spkr -
WT
Right Front Spkr +
18
PK
Right Front Spkr -
L.BU
Left Rear Spkr +
L.GN
Left Rear Spkr -
YW
Right Rear Spkr +
GN
Right Rear Spkr -
WT
I believe the factory service manuals are available somewhere on this site, the complete wiring diagram is included. You can also search my username for my install thread. A couple other members who've done full installs have replies there: LogicallySick and Tommy40, I think.
