Will TPMS work if you change rims size or tire size
Hello all,do you have any idea if I changed my rims to 20" will the tpms work properly or it will not work , I have 18" in my 8th gen maxima sv
Also if i changed the tire size only from the Oem size 245/45/18 to 255/40/18 or wider one on the same oem rims .... will the tpms work or it's only programmed to check the pressure for the oem size ??
They will work just fine, however not sure if it'll read same speed rotational with your speedo not showing the right speed. I know I had problem with Ford Mustang I went larger wheel and threw engine light which was speed sensor was not reading correct corresponding to the Transmission speed. I had to get reprogram
