Brake fluid
Old Sep 25, 2017 | 09:56 PM
mikeymax17's Avatar
Brake fluid
Should the brake fluid be upgraded to a different type when doing the akebono brake upgrade? Pulled the trigger on this mod and just want to make sure before I move forward.
Old Sep 26, 2017 | 06:22 AM
A36-SR's Avatar
You don’t have to , but i did use synthetic lucas dot4.
Old Sep 26, 2017 | 06:54 PM
dentnshell's Avatar
My $0.02 - Changing brake fluid is never a bad idea (Unless you do it wrong!) Brake fluid tends to absorb moisture and does need to be changed periodically to maintain performance. That being said most people on the road will never notice a difference in an upgrade or change. Changing your fluid from DOT3 to DOT4 or DOT 5.1 For the most part simply increases the boiling point of the fluid. For road racing my Camaro, that is an issue as the fluid will boil and the brakes become very spongy. As a daily driver... not an issue. A lot of fluids that you buy now are labeled as DOT3/4, essentially DOT4 keeping the DOT3 nomenclature to help keep from confusing people.
STAY AWAY FROM DOT5. In order to use DOT5 you will need to completely drain and flush your old fluid as 5 is silicone based unlike the DOT 3,4, and 5.1 Polyethylene-Glycol based products. If you mix the two types (DOT5 AND ANY OTHER) you will turn your fluid to GEL pretty much ruining your system.
Should you upgrade??? That is up to you... Is it really an upgrade... Only if you road race, spend lots of time with spirited driving in the hills , or just "Want" to. The fluids do degrade over time mostly from absorbing moisture (which is where the "Wet boiling point" comes into play.
Dry boiling point Wet boiling point
DOT 3 205 °C (401 °F) 140 °C (284 °F)
DOT 4 230 °C (446 °F) 155 °C (311 °F)
DOT 5 260 °C (500 °F) 180 °C (356 °F)
DOT 5.1 260 °C (500 °F) 180 °C (356 °F)
New pads or rotors will have no effect on what fluid you need. How you drive can have an impact.
And then heaven forbid we start a discussion on the best brand
Old Sep 26, 2017 | 07:17 PM
A36-SR's Avatar
Thank you for the infoðŸ‘
Old Sep 26, 2017 | 07:23 PM
mikeymax17's Avatar
Originally Posted by dentnshell
My $0.02 - Changing brake fluid is never a bad idea (Unless you do it wrong!) Brake fluid tends to absorb moisture and do need to be changed periodically to maintain performance. That being said most people on the road will never notice a difference in an upgrade or change. Changing your fluid from DOT 3 to DOT4 or DOT 5.1 For the most part simply increases the boiling point of the fluid. For road racing my Camaro, that is an issue as the fluid will boil and the brakes become very spongy. As a daily driver... not an issue. A lot of fluids that you buy now are labeled as DOT3/4, essentially DOT4 keeping the DOT3 nomenclature to help keep from confusing people.
STAY AWAY FROM DOT5. In order to use DOT5 you will need to completely drain and flush your old fluid as 5 is silicone based unlike the DOT 3,4, and 5.1 Polyethylene-Glycol based products. If you mix the two types you will turn your fluid to GEL pretty much ruining your system.
Should you upgrade??? That is up to you... Is it really an upgrade... Only if you road race, spend lots of time driving in the hills , or just "Want" to. The fluids do degrade over time mostly from absorbing moisture.
Wow thanks a lot for the info man. I think I’ll go ahead and have the system flushed and new fluid put in, since like you said it won’t hurt. Just gonna stick with whatever fluid is in the car now
